Bearings and Seals for 1939 B Transmission
Allis B Transmission
PostPosted: Sun Nov 10, 2013 7:28 am    Post subject: Bearings and Seals for 1939 B Transmission Reply to specific post Reply with quote
Would any of you possibly have the part numbers for all the bearings and seals necessary to completely overhaul a 1939 Allis "B" tractor transmission?
Thank you in advance.
charlespretzer
PostPosted: Sun Nov 10, 2013 2:27 pm    Post subject: Re: Bearings and Seals for 1939 B Transmission Reply to specific post Reply with quote
My ago dealer had them but alittle pricey.
Ted in NE-OH
PostPosted: Sun Nov 10, 2013 3:17 pm    Post subject: Re: Bearings and Seals for 1939 B Transmission Reply to specific post Reply with quote
All bearings and seals in the B transmission are standard off the shelf. Take your old bearings and seals to a bearing supply house and they can match. If you can read the numbers you can do an on line search. Those would be the cheapest choices. A little more expensive would be NAPA.
Good luck.
steve(ill)
PostPosted: Sun Nov 10, 2013 3:49 pm    Post subject: Re: Bearings and Seals for 1939 B Transmission Reply to specific post Reply with quote
here are a few numbers to get started---
Transmission & Differential:
Differential Carrier Seal - CR #11343, National #410163R
Differential Carrier/Bull Pinion Speedi-Sleeve - CR #99125
Differential Carrier Cup - Timken #25520
Differential Carrier Cone - Timken #25580
Input Shaft Cup - Timken #15250
Input Shaft Cone - Timken #15120
Input Shaft Seal - CR #11800, National #450162 (471765)
Front Pinion Cup - Timken #15250?
Front Pinion Cone - Timken #15120?
Rear Pinion Cup - ?
Rear Pinion Cone - ?
Jerry Coulter
PostPosted: Thu Nov 14, 2013 2:19 pm    Post subject: Re: Bearings and Seals for 1939 B Transmission Reply to specific post Reply with quote
rear pinion Timken numbers: cup 3821, cone 3876
