Massey 65 diesel
Michelle Bailey
PostPosted: Mon Nov 11, 2013 7:22 am    Post subject: Massey 65 diesel Reply to specific post Reply with quote
Hi:
Is it possible to put a recirculating heater on a Massey 65 diesel? If so....where do I connect the top and bottom ends?
Tequila
PostPosted: Mon Nov 11, 2013 7:47 am    Post subject: Re: Massey 65 diesel Reply to specific post Reply with quote
Because you supplied so little info. I am going to assume you mean a coolant heater that plugs in to warm the engine in cold weather. There is a pipe plug access near the rear lower right hand side of the block, then you have to hang heater hose and the heat unit connected to a tee fitting back into the thermostat housing. It's a cumbersome, bulky mess. Or you could purchase the freeze plug block heater unit. (Under $40). Pop a freeze plug, install, and you have a clean simple block heater. If you really want one of the exterior units, I have one I was going to throw away, your welcome to it.
Brendon Warren
PostPosted: Mon Nov 11, 2013 8:13 am    Post subject: Re: Massey 65 diesel Reply to specific post Reply with quote
I agree with Tequila. Mine all have an element that go in the softplug. My aftermarket waterpump does have a pipeplug to hook to, but you'd still have to plumb a return into the block. I think the softplug heater would be a lot simpler fix.
Larry in WNY
PostPosted: Mon Nov 11, 2013 9:34 am    Post subject: Re: Massey 65 diesel Reply to specific post Reply with quote
Look for the type that can be spliced into the lower radiator hose. We have one in our MF 205 diesel and Ford 2N. Not as high wattage as circulating type, but work fine.
Larry
