How do I drop the pan from a MF 275
Tom in TN
PostPosted: Mon Nov 11, 2013 12:04 pm    Post subject: How do I drop the pan from a MF 275 Reply to specific post Reply with quote
I have never owned a Massey Ferguson tractor, so obviously, I
don't have any idea what I'm doing.
However, I have a chance to buy a MF 275 for a really good price.
It has a Perkins, 4 cylinder diesel engine with an oil leak in the
area of the rear main seal.
Is it possible to drop the oil pan without removing the engine? Is
it then possible to replace a rear main seal from the bottom of
the engine?
Thanks for any help you can give to me. I'd like to buy the
tractor, but because of my lack of familiarity with Massey
Fergusons, I'm a bit reluctant to do so.
Tom in TN
samn40
PostPosted: Mon Nov 11, 2013 12:55 pm    Post subject: Re: How do I drop the pan from a MF 275 Reply to specific post Reply with quote
The rear main seal on a 275 should go in behind the flywheel after removing the clutch and flywheel. You do not have to remove the oil pan. I am sure these 236 engines will be the lip seal type, usually a very reliable seal.
Sam
Tom in TN
PostPosted: Mon Nov 11, 2013 4:56 pm    Post subject: Re: How do I drop the pan from a MF 275 Reply to specific post Reply with quote
Thanks Sam,
It seems obvious from your post that I will have to split the tractor. Hmmm. That's not what I wanted to hear.
Thank you for your reply.
Tom in TN
supergrumpy
PostPosted: Tue Nov 12, 2013 5:42 am    Post subject: Re: How do I drop the pan from a MF 275 Reply to specific post Reply with quote
more bad news
leaky rear seal might be caused by worn main bearings, low oil pressure when engine is warm is the tip off
