Allis chalmers wc won't run
76redfred
PostPosted: Mon Nov 11, 2013 4:51 pm    Post subject: Allis chalmers wc won't run Reply to specific post Reply with quote
Hello I am working on a allis chalmers wc, and I am to the point where I am trying to start the tractor. I believe I have the mag timed right on the engine. I went thru the steps i found with TDC and then rotate back to the fire mark. I put a new zenith carb on it and have good gas going to the carb. I crank the tractor over and it will try to start and then keep cranking, then gas will seep out of the bottom of the carb. And then every one in a while it will backfire maybe once and sound like a gun going off. But then try to fire.
Des anyone have any specific suggestions I can do to try and get the tractor going, thanks for any help!
VicS
PostPosted: Mon Nov 11, 2013 5:03 pm    Post subject: Re: Allis chalmers wc won't run Reply to specific post Reply with quote
Sounds like you are 180 off maybe. Be calm, start over take nothing you have done for granted.
chalmersbob(Pa)
PostPosted: Mon Nov 11, 2013 6:56 pm    Post subject: Re: Allis chalmers wc won't run Reply to specific post Reply with quote
Did you remove plug #1 and hand crank until you felt air coming out of the plug hole? Then with a wire, hand crank until the piston is at the top. Then install the mag. LOL Bob
bjb in TX from Ne
PostPosted: Tue Nov 12, 2013 5:16 am    Post subject: Re: Allis chalmers wc won't run Reply to specific post Reply with quote
I second the 180 degrees off. I had the same problem when I first tried starting my WC. Re did the timing from scratch again and it fired right up.
