MF2775 PTO shaft
jkloepping
PostPosted: Tue Nov 12, 2013 4:58 pm    Post subject: MF2775 PTO shaft Reply to specific post Reply with quote
I"m trying to remove the rear pto shaft from the pto clutch on my massey 2775. The shaft slides smoothly about an inch, and then stops hard, like there is a snap ring or something, not like messed up splines. The service manual says the shaft should just slide out, and I"ve spoken to another owner with a 2805 that slides out, so my next move is to block the pto clutch and use a slide hammer. Sure hate to do that without asking here first if anyone has seen this problem before?
The only thing I can think of, is that the clutch was overheated previously and the internal hub has seized on the shaft splines. That would only make sense if the internal hub can move an inch or so in the pto clutch. Otherwise, I can"t imagine why it would move an inch and then stop.
FBH44
PostPosted: Wed Nov 13, 2013 2:27 am    Post subject: Re: MF2775 PTO shaft Reply to specific post Reply with quote
Something tells me not to use the slide ehammer. How would you reassemble it?
moresmoke
PostPosted: Wed Nov 13, 2013 5:09 am    Post subject: Re: MF2775 PTO shaft Reply to specific post Reply with quote
Are you working on the upper or lower (stub) shaft?
jkloepping
PostPosted: Wed Nov 13, 2013 7:28 am    Post subject: Re: MF2775 PTO shaft Reply to specific post Reply with quote
Upper shaft, the one behind the attach point for the top link.
moresmoke
PostPosted: Wed Nov 13, 2013 7:26 pm    Post subject: Re: MF2775 PTO shaft Reply to specific post Reply with quote
Should just be splined into the clutch center hub.
jkloepping
PostPosted: Sat Nov 16, 2013 7:23 pm    Post subject: Re: MF2775 PTO shaft Reply to specific post Reply with quote
Problem solved. I dismantled the PTO clutch through the left side cover and removed it that way. Turns out that the shaft bushing had seized on the shaft and that was preventing me from extracting it. Looks like the slide hammer would have worked eventually, but this was the safer method.
