power steering cylinder o rings MF 65
Andrew in Georgia
PostPosted: Sun Nov 17, 2013 8:21 am    Post subject: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
Mornin All, I have a question. My 65 has leaked fluid from the steering ram for a while and I decided to pull it apart for a look. I found the cylinder shaft had a rough spot and this had grooved the o ring and wiper giving chance to leak. My shop book covers three pump models and is a reproduction of the original so I"ve no idea what "kit" I would buy. The ram/cylinder has only 6 o rings ( I did not open the smaller power assist cylinder as it isn"t leaking..yet) with two of these, one is the wiper, being odd shaped. The rest I could find in the hardware store. Anyone have any ideas? Thanks for your time.
Dieseltech
PostPosted: Sun Nov 17, 2013 8:49 am    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
If I remember correctly there were 2 power steering cylinders used, one was a welded model, and one had 4 tie rod bolts. Find what you have in the parts list as the kits were different.
Andrew in Georgia
PostPosted: Sun Nov 17, 2013 9:40 am    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
Thank you Sir, it has the bolts. I believe it is the Wooster pump if that helps with the type. The ram piston has no o rings or washers but has two metal rings like an engine's piston.
Something I'm curious about is, under the red and grey paint the tractor seems to be yellow. I have a repro brochure showing a yellow model industrial tractor. I wonder if this makes a difference in part listings?
patiolant
PostPosted: Sun Nov 17, 2013 11:47 am    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
When I did mine a few years ago, the dealer kit was universal for both types of cylinders (mine had the bolts) so there were parts left over.
Andrew in Georgia
PostPosted: Sun Nov 17, 2013 12:08 pm    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
Thanks, would you happen to know the stock number of the kit? I've been searching for hours and think I have the cylinder part number as 183074M91. Strange as it sounds this info is NOT in the shop manual that I have. It has pictures and descriptions but no part numbers. I've surfed the kit pictures and don't see the oddball seals I need. I am happy to see the piston rod is available for 30 bucks. Mine has a rough patch that I took out with some 400G sandpaper going around the shaft, not along the length of it. If that doesn't work then I can get a new one.
patiolant
PostPosted: Sun Nov 17, 2013 5:09 pm    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
830860M92. I did both the main and the power assist cylinder, and all seals I needed were in the kit. As said above, my main cylinder was the one with four large bolts holding it together. Good luck with it.
Andrew in Georgia
PostPosted: Sun Nov 17, 2013 5:35 pm    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
I do thank you. After the entire afternoon searching I found the same number but it is great to hear a confirmation that it is correct. I found these kits from Turkey priced at 5.50 each, but you have to buy 1000 kits at a time. Looks like I'm spending about 70 bucks for the kit.
Larry in WNY
PostPosted: Thu Nov 21, 2013 9:39 am    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
My 65 gas utility model is still yellow. It doesn't have a PTO or 3 point hitch. It has a heavy duty loader on it.
Larry
Andrew in Georgia
PostPosted: Fri Nov 22, 2013 3:32 pm    Post subject: Re: power steering cylinder o rings MF 65 Reply to specific post Reply with quote
any idea why the different color? Have you noticed that any "normal" parts do not fit? By the way, I had a headlight that was not working but tested good with ohm meter. Found a brass grounding tang that has to contact the metal housing for the bulb to work. The bulb had been installed 180 degrees from factory and the tang couldn't touch metal. I recently made a bracket and installed an alternator, saved the dynamo for later rewind.
