Ballast Resistor
BIGR
PostPosted: Sun Nov 17, 2013 12:30 pm    Post subject: Ballast Resistor Reply to specific post Reply with quote
What does a ballast resistor do? I am wiring up a Worthington Tractor that I picked up. It has a Ford Model "B" engine which is similar to the 9N. I'm using a Ford Model "B" Car and a Ford 9N wiring diagram as a guide. Both diagrams show a resistor before the coil. The Worthington's old wiring harness did not have a resistor. Do I need one? I am adding lights and it's still 6V Positive Ground. If I need one can I use one from a 9N?
Bruce (VA)
PostPosted: Sun Nov 17, 2013 1:29 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
a true ballast resistor, as opposed to a fixed resistor, has minimal resistance when cold & increases resistance as it heats up. The purpose is to allow max current to the coil for start up & then reduce current while the engine as running.
It depends on the internal resistance of the coil you are using.
For example, a front coil (2N & 9N) had a very low internal resistance (.3 to 1.5 ohms) and requires a ballast resistor. An 8N w/ a round coil does not need a ballast resistor because the internal coil resistance is greater than 3.25 ohms.
The A model Ford used a round coil, no ballast resistor. AFAIK, the 4 cylinder B model Ford engine also used a round coil & probably does need a resistor. But, to be sure, just measure the internal coil resistance.
And BTW, a B model Ford engine is only similar to an N engine in that it's a 4 cylinder flat head.
BIGR
PostPosted: Sun Nov 17, 2013 3:54 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
Ok, how do you test the resistance? Also, is there such a thing as using the resistor and not harm anything if you don't need it. Can I use one from the 9N? I have one sitting on the shelf?
Thanks for the help!
Bruce (VA)
PostPosted: Sun Nov 17, 2013 3:59 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
'how do you test the resistance?'
With a multi-meter. Set it on resistance.
' is there such a thing as using the resistor and not harm anything if you don't need it.'
Too much resistance in the ignition circuit will make it hard to start & run poorly because of a weak spark.
' Can I use one from the 9N?'
You just don't stick a resistor in a circuit w/o knowing what the coil will handle. The 9N OEM ballast resistor is about .3 ohms cold & 1.7 ohms hot. It might be too much or too little resistance.
What does your coil look like?
BIGR
PostPosted: Sun Nov 17, 2013 4:08 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
It's a round coil and it says Delco-Remy 6V on it.Looks like it's the original? At least simlilar to what the original was.
HCooke
PostPosted: Sun Nov 17, 2013 4:29 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
A 6 V round coil needs no resistance as long as you are using a 6 volt battery.
Royse
PostPosted: Sun Nov 17, 2013 4:33 pm    Post subject: Re: Ballast Resistor Reply to specific post Reply with quote
As said, the round can doesn't need the resistor @ 6V.
The 9N/2N and early 8N did not have a round coil, they used
the square coils so you will see it in all of their wiring diagrams.
