8n electrical
wayne bullen
PostPosted: Sun Nov 17, 2013 2:04 pm    Post subject: 8n electrical Reply to specific post Reply with quote
I have a 50 8n side mount. when I take a voltmeter reading across the battery terminals with the engine off, I get a normal 6.2v reading. but when I try it with the engine running, the voltmeter goes crazy and I can"t get any reading. why would this be?
JMOR
PostPosted: Sun Nov 17, 2013 2:07 pm    Post subject: Re: 8n electrical Reply to specific post Reply with quote
Electrical noise originating in gen, VR, ignition system scrambles the digital meter's brain. Get an analog meter or alternatively a much more expensive digital meter than the one you are using.
BillM (OH)
PostPosted: Sun Nov 17, 2013 2:08 pm    Post subject: Re: 8n electrical Reply to specific post Reply with quote
tractor running drives digital meters crazy - need to get an analog meter and you will be fine.
Bruce (VA)
PostPosted: Sun Nov 17, 2013 2:23 pm    Post subject: Re: 8n electrical Reply to specific post Reply with quote
As Bill & JMOR said......tip # 47.
75 Tips
Royse
PostPosted: Sun Nov 17, 2013 2:54 pm    Post subject: Re: 8n electrical Reply to specific post Reply with quote
As said, analog. And a cheap analog meter works just fine,
but before you buy one check the available voltage scales.
Some have a 10V scale which works fine on a 6V system.
However if you want to use it on a 12V system and the next
scale is 250V, it's not of much use on the 12V system. BTDT
wayne bullen
PostPosted: Sun Nov 17, 2013 3:28 pm    Post subject: Re: 8n electrical Reply to specific post Reply with quote
thanks very much, guys. I had never heard that
souNdguy
PostPosted: Mon Nov 18, 2013 5:51 am    Post subject: Re: 8n electrical Reply to specific post Reply with quote
mostly it's a smaple rate issue with the cheaper consumer grade meters... etc.
