310 camshaft specs needed
bison
PostPosted: Sun Nov 17, 2013 3:06 pm    Post subject: 310 camshaft specs needed Reply to specific post Reply with quote
I'm in the process of rebuilding a 310.
The camshaft lobes are somewhat worn me thinks but i don't know the original specs.
highest lobe measures 1.4185 with calipers across the shaft or with a straightedge held against the bearings it will pass a .128 feeler gauge between the lobe and the straight edge.
Lowest lobe(only one) has a across measurement of 1.3680 or a full .425 shorter than the highest one Shocked
If i need an other camshaft,...were to get?
Also looking for 2 rods.
J. Schwiebert
PostPosted: Sun Nov 17, 2013 3:45 pm    Post subject: Re: 310 camshaft specs needed Reply to specific post Reply with quote
Yea I can look the dimension up in the morning. Also remember if this is for a diesel they came out with a little "improved version" The dimensions I will give you will be for lift.
bison
PostPosted: Sun Nov 17, 2013 8:17 pm    Post subject: Re: 310 camshaft specs needed Reply to specific post Reply with quote
J. Schwiebert wrote:
(quoted from post at 16:45:04 11/17/13) Yea I can look the dimension up in the morning. Also remember if this is for a diesel they came out with a little "improved version" The dimensions I will give you will be for lift.
Yes this is a diesel.
J. Schwiebert
PostPosted: Mon Nov 18, 2013 4:21 am    Post subject: Re: 310 camshaft specs needed Reply to specific post Reply with quote
Lift is given as 0.302 for both intake & exhaust. Questions send me an e-mail. J.
dboll
PostPosted: Wed Nov 20, 2013 6:27 am    Post subject: Re: 310 camshaft specs needed Reply to specific post Reply with quote
why don't you get it reground?
bison
PostPosted: Wed Nov 20, 2013 8:18 am    Post subject: Re: 310 camshaft specs needed Reply to specific post Reply with quote
To costly Shocked
