massey 44 throttle cable
cavanhills
PostPosted: Sun Nov 17, 2013 7:19 pm    Post subject: massey 44 throttle cable Reply to specific post Reply with quote
have a 44 with a badly siezed throttle cable, how you remove the slip end that attaches from the goverener. the spiral cable goes into, tried to spin off, no luck. hoping to use a universal choke cable to replace the exisiting throttle cable. (wrappped steel around wire) any help would be great
David G
PostPosted: Sun Nov 17, 2013 8:58 pm    Post subject: Re: massey 44 throttle cable Reply to specific post Reply with quote
44-4 uses throttle shaft, is this 44-6?
Dieseltech
PostPosted: Mon Nov 18, 2013 4:10 am    Post subject: Re: massey 44 throttle cable Reply to specific post Reply with quote
The early 44 I had the cable was stuck at the bend under the fuel tank. Kept soaking it and finally got it to move, but it took time.
cavanhills
PostPosted: Mon Nov 18, 2013 6:01 am    Post subject: Re: massey 44 throttle cable Reply to specific post Reply with quote
Nope, it"s a regular 44 row crop. 48-49. Has the wound cable that feeds through the tube and down to governor. There is a piece that attaches the throttle to the governor. The cable is badly seized and kinked where cable inserts the tube under fuel tank
David G
PostPosted: Mon Nov 18, 2013 12:46 pm    Post subject: Re: massey 44 throttle cable Reply to specific post Reply with quote
NAPA should sell bulk cable.
cavanhills
PostPosted: Mon Nov 18, 2013 10:55 pm    Post subject: Re: massey 44 throttle cable Reply to specific post Reply with quote
yup, have the cable.... but how does the cable attached to the piece which, attaches to governor spring?
David G
PostPosted: Wed Nov 20, 2013 3:43 pm    Post subject: Re: massey 44 throttle cable Reply to specific post Reply with quote
I do not know, mine is a late model with throttle rod.
I would pull up the web site parts diagram.
