ford 4000 old not sure maybe 60's
thomas w stinson
PostPosted: Wed Nov 27, 2013 10:25 am    Post subject: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
trying to remove head, oil line will not come up everthing is loose took pan dn no conection there line swivles and moves but will not come out please advise thank you in advance
Jr in nwmo
PostPosted: Wed Nov 27, 2013 11:50 am    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
as I remember its got an o ring on it that becomes hard with age,you may have to pull on it,sounds like its a pre 65 model 4cyl?
Sean in PA
PostPosted: Wed Nov 27, 2013 12:02 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
You should always specify which version of the 4000 tractor that you're talking about. There were 2 different 4000 series Ford tractors. The earlier one had a 4 cylinder engien and the later one had a 3 cylinder engine, but the cut-over date between them was 1956, so they were both made in the 1960's.
I assume that since you're talking about the oil tube that it is the earlier4 cylinder version. I haven't ever had to pull a head on one of those so i don't have any first hand experience, but I've read of similar problems from others wen trying to get the tube out. If you searhc through the archive s her you might find some tricks that others have used to get them out. Or hopefully one of those folks will come along shortly and give you some advice.
cbrown9064
PostPosted: Wed Nov 27, 2013 12:12 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
Sean in PA wrote:
(quoted from post at 16:02:07 11/27/13) You should always specify which version of the 4000 tractor that you're talking about. There were 2 different 4000 series Ford tractors. The earlier one had a 4 cylinder engien and the later one had a 3 cylinder engine, but the cut-over date between them was 1956, so they were both made in the 1960's.
Got your numbers twisted while typing Sean! 1965...
Chris
Will Gumbert
PostPosted: Wed Nov 27, 2013 12:17 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
As others said, this assumes earlier 4-cylinder engine.
Shop manual shows grasping it with pliers, but be careful. I would suggest cutting a piece of rubber tubing, slit it and slide it over the tube and then try the pliers. -Will
Sean in PA
PostPosted: Wed Nov 27, 2013 1:04 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
cbrown9064 wrote:
(quoted from post at 16:12:57 11/27/13)
Chris
Yeah, my fingers never listen to my brain when I'm typing. I usually read back over a post about 10 times and fix mistakes like that before I actually click on the submit button, but some still make it through anyway.
thomas w stinson
PostPosted: Wed Nov 27, 2013 1:25 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
thank you for the info, I tried pulling on it but it seemed so solid at the pt of resistance, so i quit your right about the typo's and yes it apparently is pre 65 I'll give it another crack using your suggestion of rubber insulate I'll let you know.
Tom
WayneIA
PostPosted: Wed Nov 27, 2013 2:34 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
It is possible that the oil line may not be in it"s original shape when you get it out of the tractor. A vice grip leveraged over the rocker arms and twist will get it buuuut!!!!! Some of them can be tough cookies.
showcrop
PostPosted: Wed Nov 27, 2013 6:49 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
Just get a good grip on it and yank it out. better than damaging it with pliers. If the grommet is bad it is bad, you can find some material to stick on there to seal and hold it.
souNdguy
PostPosted: Thu Nov 28, 2013 3:20 pm    Post subject: Re: ford 4000 old not sure maybe 60's Reply to specific post Reply with quote
oil it with a lil atf. make sure hold downs loose. and twist while pulling.
if the grommet is tight.. it will be ahrd.. but should move with twisting.
