Ford 260C
Ultradog MN
PostPosted: Wed Nov 27, 2013 3:07 pm    Post subject: Ford 260C Reply to specific post Reply with quote
I'm not familiar with this machine.
And Tractordata is mostly empty on it.
Is there anything you all know about it?
He says it's 65 hp.
It must be a 4 cyl to get that?
What about the transmission and pto he talks about. Would this be independent pto?
Shuttle shift?
I do really like the old 8sp crash box.
Sometimes I think about going to a little newer machine. Maybe something with FWA or if not that then at least get away from the wishbone front axle. For sure I'd want a 201, IPTO and wet brakes. I see the 3910 could be had with FWA and the 3930 had a better front axle though they are probably too new for my wallet.
What is the difference between a 260C and a 250C?
Or what other industrial models are relatively short and stout? Newer than 1982 and with the upgraded hydraulics.
260C
mhb@ufe
PostPosted: Wed Nov 27, 2013 3:20 pm    Post subject: Re: Ford 260C Reply to specific post Reply with quote
The 260C uses a torque converter driven power reversing 8 speed transmission with an electronic lock-up function for the torque converter and independent PTO, 3 cylinder rated at 63hp and the 250C is 52hp.
Mark
Will Gumbert
PostPosted: Wed Nov 27, 2013 3:27 pm    Post subject: Re: Ford 260C Reply to specific post Reply with quote
There's one on tractorhouse that looks similar to the one you mentioned and says it's a 1992 and lists 52hp. With that dozer blade, you could really move some snow up there with a heavy duty machine like that. Turf tires would be easy to get chains on. -Will
