Farmall h wide front
1949farmallH
PostPosted: Wed Nov 27, 2013 7:36 pm    Post subject: Farmall h wide front Reply to specific post Reply with quote
I was wondering if anyone knew if I can make a wide front from a M fit on my H?
David G
PostPosted: Wed Nov 27, 2013 7:40 pm    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
I have an early H WF with new tires I want to get rid of.
Janicholson
PostPosted: Wed Nov 27, 2013 7:45 pm    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
Not without dramatic effort. The bolt pattern on the bolster is different, the frame rails are 2" different, and the Y brace attachment is different. If close, take David G's offer. Jim
Stumpy(NH)
PostPosted: Thu Nov 28, 2013 4:27 am    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
Where are you and what do you want for it?
David G
PostPosted: Thu Nov 28, 2013 6:19 am    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
Eastern Iowa, $350
1949farmallH
PostPosted: Thu Nov 28, 2013 10:49 am    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
I would but its about 6 hours from me. I can buy one with all linkage and good tires for 150 bucks. I'm good with a welder so I think I'll be able to fabricate something
Crookedwrench
PostPosted: Thu Nov 28, 2013 5:28 pm    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
Interested in the WF w Tires for H. E-mail me with some info at dwb2611@roadrunner.com
PaulGinMn
PostPosted: Fri Nov 29, 2013 2:38 pm    Post subject: Re: Farmall h wide front Reply to specific post Reply with quote
the wide front under my H was from a M I took the big plate off and milled down the side to make it narrower. I have seen someone good with a torch use a straight edge and cut the sides as well. I also set up the part that bolts to the boaster in the mill and slotted the 2 holes to make it fit. My part was all welded up so wasn't to worried about wreeking a good one.
