464 carb troubles
Seanchev
PostPosted: Thu Nov 28, 2013 9:48 am    Post subject: 464 carb troubles Reply to specific post Reply with quote
I have a IH 464 the carb is shot I can't find a new marvel schriver carb so I bought a zenith with out the fuel shut off solenoid. Do you think I should go with the Zenth or try to find the correct carb
Bob
PostPosted: Thu Nov 28, 2013 11:13 am    Post subject: Re: 464 carb troubles Reply to specific post Reply with quote
If the carb you have will bolt up and the linkage will connect, WHY not run it and try it?
pete 23
PostPosted: Thu Nov 28, 2013 11:41 am    Post subject: Re: 464 carb troubles Reply to specific post Reply with quote
I would use the zenith provided it is the correct replacement carburetor. I feel they do a better job of metering the fuel throughout the entire operating speeds and loads than a Marvel Schebler ever did. I'm talking about new carburetors now, tractors right from the factory, not old worn out ones.
As far as the electric shut off, your new carb should be able to idle that engine down nice and slow for shut down without dieseling.
Haas
PostPosted: Thu Nov 28, 2013 4:26 pm    Post subject: Re: 464 carb troubles Reply to specific post Reply with quote
Friend has a 464. Never got it to run right until he got the zenith carb without the solenoid cut off.
