134 Engine backfire
LarryTN
PostPosted: Thu Nov 28, 2013 4:52 pm    Post subject: 134 Engine backfire Reply to specific post Reply with quote
I posted early about this tractor and got some good advise, however after trying them all I still have a problem, The engine is missing causing the backfire I think. Check compression #1-120, #2- 110 #3-110 #4-120 so I check the spark and this is what I found a good blue spark to each plug, jump about one half inch. Now when I pull #1 or #4 wire it will stop the engine running But if I pull #2 or #3 plug wire nothing happen has no affect on the engine. Spark plug
are almost new so I swap them around to make sure it wasn't bad plugs and I still have same problem.
All advise is welcome..........Thanks Larry
David G
PostPosted: Thu Nov 28, 2013 5:18 pm    Post subject: Re: 134 Engine backfire Reply to specific post Reply with quote
Do you have 2 and 3 plug wires swapped?
WayneIA
PostPosted: Thu Nov 28, 2013 5:35 pm    Post subject: Re: 134 Engine backfire Reply to specific post Reply with quote
Are you sure you have the plug wires on the right plugs.? Firing order is 1 (front of engine) 2-4-3. Distributor turns clockwise. If the distributor is install into the block as per factory! Number 1 on the cap should be at about 8 o"clock, NO 2 at 10 o"clock, No 4 at 2 o"clock and 3 at 4 o"clock.
David G
PostPosted: Thu Nov 28, 2013 6:23 pm    Post subject: Re: 134 Engine backfire Reply to specific post Reply with quote
Wayne, I am thinking the same thing, 2 and 3 are swapped. It is pretty easy to get the firing order backwards.
souNdguy
PostPosted: Fri Nov 29, 2013 2:09 pm    Post subject: Re: 134 Engine backfire Reply to specific post Reply with quote
deffinately sound slike you could have a fire order issue..
LarryTN
PostPosted: Sat Nov 30, 2013 8:10 am    Post subject: Re: 134 Engine backfire Reply to specific post Reply with quote
Thanks to all for your help my eye site is going I did have 2 & 3 crossed
Larry
David G
PostPosted: Sat Nov 30, 2013 9:55 am    Post subject: Re: 134 Engine backfire Reply to specific post Reply with quote
Great news, easy fix and common mistake.
