Saginaw lift capacity
BigTone
PostPosted: Thu Nov 28, 2013 6:10 pm    Post subject: Saginaw lift capacity Reply to specific post Reply with quote
Hey boys, I was wondering if anyone knew the lift capacity of the Saginaw hitch running on a belly pump? I have heard people pick up large round bails with it. I'm looking into a rear blade in the 350-500lbs range and just want to make sure it can lift it. Will it lift more than 500lbs? Thanks, Anthony
Zachary Hoyt
PostPosted: Thu Nov 28, 2013 7:47 pm    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
In general with 3 point hitches they should be able to lift quite a bit more than that. The further from the ends of the lift arms the weight is the "heavier" it is, if that makes sense, it is about leverage. If your belly pump is working at all 500# should be an easy lift.
Zach
IAtractorKid
PostPosted: Thu Nov 28, 2013 7:50 pm    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
Those hitches are stout. 500lbs would be nothing for one. Guys use them daily for 1200-1500lb round bales around here. I would not doubt the hitch could handle up to 2000lbs.
leeedwin9
PostPosted: Thu Nov 28, 2013 9:12 pm    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
I have a Farmall M w/belly pump and a Saginaw hitch. I use it to power my Land Pride 3-pt hitch 90" grooming mower. The mower weighs 1,100 pounds. The Saginaw and belly pump lift the deck easily.
Allan in NE
PostPosted: Fri Nov 29, 2013 3:54 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
That hitch will lift the whole derned tractor if ya ask 'er to. :>)
Allan
Ellis Kinney
PostPosted: Fri Nov 29, 2013 8:14 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
Anthony, Here is a picture of my M and the Saginaw. These are 1500# bales. Ellis
Ellis Kinney
PostPosted: Fri Nov 29, 2013 8:18 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
Actually, It will lift the bale plus 2 grandkids sitting on it. Ellis
tractor300
PostPosted: Fri Nov 29, 2013 8:34 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
How do you keep the front end on the ground? I had one on a Super M with wide front and could not keep the front end on the ground without adding weight with 1200# bales.
Janicholson
PostPosted: Fri Nov 29, 2013 10:03 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
It will rest there, good wheel brakes are the steering!! I have practice on a 350U with a FH disk! Jim
Ellis Kinney
PostPosted: Fri Nov 29, 2013 10:48 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
Tractor300-- It does just fine unless I go up a hill, and then it is brake steering. It doesn't seem logical, but maybe it is how high you lift it. Notice in my picture the bale isn't as high as the 3pt hitch will lift. Ellis
JDnTN
PostPosted: Fri Nov 29, 2013 2:30 pm    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
Ellis, that seat looks comfortable. What kind is it and where can they be found? Difficult to mount?Thanks, JD
heavyhaulertoo
PostPosted: Sat Nov 30, 2013 7:17 am    Post subject: Re: Saginaw lift capacity Reply to specific post Reply with quote
You don't need power steering then .ha.
