Super C wiring
Don Hanvey
PostPosted: Thu Nov 28, 2013 8:07 pm    Post subject: Super C wiring Reply to specific post Reply with quote
Would it be better to stay with a positive ground or could I change it to a negative ground?
Is there a wiring diagram available on the net?
Janicholson
PostPosted: Thu Nov 28, 2013 8:32 pm    Post subject: Re: Super C wiring Reply to specific post Reply with quote
It does not matter which unless you put in an alternator. in which case negative ground is easier and cheaper.
Bob M diagrams
Janicholson
PostPosted: Thu Nov 28, 2013 8:37 pm    Post subject: Re: Super C wiring Reply to specific post Reply with quote
To set it up negative ground, put the battery in with negative ground. Do not stert it. Use a piece of #10 wire (solid wire copper with vinyl insulation is good) to jump across the regulator from Bat to Arm terminals. You will need to reverse the wiring on the amp meter as the meter will read backwards if you do not. Jim
teddy52food
PostPosted: Fri Nov 29, 2013 6:50 am    Post subject: Re: Super C wiring Reply to specific post Reply with quote
Mine has been running fine on 6 volt positive ground since 1951. Why change it?
Don Hanvey
PostPosted: Fri Nov 29, 2013 7:32 pm    Post subject: Re: Super C wiring Reply to specific post Reply with quote
I would like to leave it original. R u still using the generator. If the battery is dead , can u jump it off with a 12 volt battery?
gene bender
PostPosted: Sat Nov 30, 2013 2:45 am    Post subject: Re: Super C wiring Reply to specific post Reply with quote
Why change ground your reg wont like it and then you will need to find a 6v neg grnd regulator to bolt where the present one is. Just leave it pos gnd.
teddy52food
PostPosted: Sat Nov 30, 2013 6:44 am    Post subject: Re: Super C wiring Reply to specific post Reply with quote
I am still using the generator. You can jump it if you know what you are doing. Best to charge the battery & find out why it is dead.
