MF 285 engine rebuild
ecar
PostPosted: Sun Dec 01, 2013 5:00 pm    Post subject: MF 285 engine rebuild Reply to specific post Reply with quote
I am doing a complete rebuild on a 1982 MF 285 Perkins A4.318 and the parts kit came with a 2 piece rope seal. I have the engine completely tore down and don't see where this goes- I can't find anything in the manual either. Anybody know where this goes?
Dieseltech
PostPosted: Sun Dec 01, 2013 6:46 pm    Post subject: Re: MF 285 engine rebuild Reply to specific post Reply with quote
Each half goes into upper and lower aluminum seal carrier grooves. Service manual shows how to correctly install them.
Masseynut(Australia)
PostPosted: Sun Dec 01, 2013 6:57 pm    Post subject: Re: MF 285 engine rebuild Reply to specific post Reply with quote
Early 318 Perkins engines have a rope rear seal, at least the 1080's here in Australia did have anyway. I'm not familiar with the 285's, as none ever came into this country as far as I know. Later engines may have come thru with a single lip type seal.
Did you also get a lip seal in your kit? If you did, I'd just bin the rope set.
unclemerle
PostPosted: Mon Dec 02, 2013 3:41 am    Post subject: Re: MF 285 engine rebuild Reply to specific post Reply with quote
Early 318"s used the seal on the rear of the crank shaft.
DavidP, South Wales
PostPosted: Mon Dec 02, 2013 2:05 pm    Post subject: Re: MF 285 engine rebuild Reply to specific post Reply with quote
Hi,
My info agrees with Evan in that all 1080 and 1085 models had a rope seal. USA-made 285's with the A4.318 and A4.318.2 engines had a black nitrile lip seal. Part number is 2418F475.
DavidP, South Wales
ecar
PostPosted: Mon Dec 02, 2013 5:19 pm    Post subject: Re: MF 285 engine rebuild Reply to specific post Reply with quote
Thanks guys.
Yep, the rebuild kit came with a lip seal also and I have that already installed. I didn't know if this rope seal was used for something other than the crankshaft.
Dieseltech, unless you are describing something different, I will toss the rope seal.
Roy in UK
PostPosted: Thu Dec 05, 2013 1:02 am    Post subject: Re: MF 285 engine rebuild Reply to specific post Reply with quote
David, Is there much difference between the 318 and 318.2? I presume the latter is an improved version of the former. Did they manage to cure the notorious head gasket blowing proclivities of that engine? I seem to remember Massey sort of "gave up" on that engine when they replaced the 698 with the 698T.
I have just been reading an excellent and very entertaining book by David Walker called "Inside Massey Ferguson" . He mentions the problems of the A4.318 fitted to the 1080/ 595 quite a lot. One of the funniest parts of the book though is when he talks about a tractor driver in Africa, who destroyed the engine in his 135 by replacing the dirty oil in the air cleaner with fresh new clean dry sand!
Massey Book
