ever had this happen ??
j hikemper
PostPosted: Sun Dec 01, 2013 7:41 pm    Post subject: ever had this happen ?? Reply to specific post Reply with quote
my 800 runs fine now ,,, BUT ,,been below freezing here alot ,,when I went to start the 800 diesel ,, cranked it over and heard a hissin wheezing compression of air ,,,the air breather was full of ice ,poor girl couldn't draw a breath ,, it was parked on the north side shady side of shop with the nose slightly out and the rain water musta come off the roof into the breather ,,I put a coffee can over muffler , but I shoulda covered the breather too ...
jon f mn
PostPosted: Sun Dec 01, 2013 8:00 pm    Post subject: Re: ever had this happen ?? Reply to specific post Reply with quote
Just had that happen to my 400. I couldn't figure out why it wouldn't start til I heard that sucking sound too. What a mess to clean up. On mine it was because someone had tightened the nut too tight on the cap and dented it down so the water sat in there. Pounded it out and added a rubber washer from a metal roof screw and it should be good now.
View user's profile AIM Address
j hikemper
PostPosted: Sun Dec 01, 2013 8:10 pm    Post subject: Re: ever had this happen ?? Reply to specific post Reply with quote
hi jon ,,,yes, it is a mess ..2nd time this happened,,, serveral years ago I left the 800 in a pourin rain while sowin wheat ..next day was hard freeze...and the 800 wouldn't even take ether??? thought then, that the rings were done because it would not draw air... the stock cap lets water in occassionaly .. I wonder if I could politely modify the cap ?
sms
PostPosted: Mon Dec 02, 2013 2:26 am    Post subject: Re: ever had this happen ?? Reply to specific post Reply with quote
I just screwed a plastic bucket bottom over my forklift air cleaner the top was made with a deep indent that fills with water. Thought I had it sealed last year but nope. Doesn"t look elegent but should keep water out.
Bret4207
PostPosted: Mon Dec 02, 2013 3:56 am    Post subject: Re: ever had this happen ?? Reply to specific post Reply with quote
Happens every fall on my 800 Ford. I end up taking the bowl off and running it open all winter.
1031D
PostPosted: Mon Dec 02, 2013 8:09 am    Post subject: Re: ever had this happen ?? Reply to specific post Reply with quote
I just changed all my oils on my 800 and now since it's cold I notice a popping out the air cleaner at idle.
