john deer 350 crawler runs rough.
Donald Montgomery
PostPosted: Thu Dec 05, 2013 7:12 am    Post subject: john deer 350 crawler runs rough. Reply to specific post Reply with quote
I Have a john deer 350 crawler with a rough running condition that comes and goes. i suspect the injector pump has a bad governer. do these pumps have a history of problems? How do you time the engine for removal of the pump?
Tx Jim
PostPosted: Thu Dec 05, 2013 8:57 am    Post subject: Re: john deer 350 crawler runs rough. Reply to specific post Reply with quote
Have you tested the injectors? There's a timing pin that holds the cover on the hole in the flywheel housing. When engine is on #1 TDC the pins fits in a depression in flywheel.
Resting Relics 1
PostPosted: Thu Dec 05, 2013 1:20 pm    Post subject: Re: john deer 350 crawler runs rough. Reply to specific post Reply with quote
Hey Don,
What pump do have on that 350. If you still have the little pump that's probably your problem. That's how they acted when they gave up. Be sure to check the easy stuff first like filters, fuel flow to the pump and injectors before you condemn the pump. Good Luck!
John
Tech 7
PostPosted: Thu Dec 05, 2013 1:38 pm    Post subject: Re: john deer 350 crawler runs rough. Reply to specific post Reply with quote
I would check the fuel transfer pump first....have seen that before
Donald Montgomery
PostPosted: Sat Dec 07, 2013 10:34 am    Post subject: Re: john deer 350 crawler runs rough. Reply to specific post Reply with quote
I had the pump rebuilt and found the governor was shot.They also found what looked like coffee grinds in it and a plugged terurn port to the tank. thanks for the input.
