1952 Oliver 77 fuse block
Paul Gi.
PostPosted: Sat Dec 07, 2013 1:31 am    Post subject: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
Restoring a 1952 77 having problems remembering where fuse block is mounted behind dash. Fuse block is hooked to a metal bracket with two rubber grommet holes for wiring. Picture of mounting location would be very helpful. Thank You in advance.
Bison2010
PostPosted: Sat Dec 07, 2013 9:25 am    Post subject: Re: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
[quote="Paul Gi."](quoted from post at 02:31:23 12/07/13) Restoring a 1952 77 having problems remembering where fuse block is mounted behind dash. Fuse block is hooked to a metal bracket with two rubber grommet holes for wiring. Picture of mounting location would be very helpful. Thank You in advanceg][img]
[/img]
This is off a48 ,not sure if it is the same
rrlund
PostPosted: Sat Dec 07, 2013 10:13 am    Post subject: Re: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
I think it hangs down off the right side of the rear gas tank support doesn't it?
OliverNate
PostPosted: Sat Dec 07, 2013 10:23 am    Post subject: Re: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
I have a 51 and mine hangs in the same spot
Larry NEIL
PostPosted: Sat Dec 07, 2013 3:50 pm    Post subject: Re: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
On the '53 I'm working on now it hangs right in the middle of the dash. It is wired for two cylinder controls.
Paul Gi.
PostPosted: Sun Dec 08, 2013 4:20 am    Post subject: Re: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
Larry do you happen to have time to post a picture of where yours is located on your 53.
Larry NEIL
PostPosted: Sun Dec 08, 2013 12:44 pm    Post subject: Re: 1952 Oliver 77 fuse block Reply to specific post Reply with quote
Sure Paul, I'll get it after church.
Larry
