tire pressure for 18.4-38
Broke again
PostPosted: Wed Dec 11, 2013 5:55 am    Post subject: tire pressure for 18.4-38 Reply to specific post Reply with quote
I've got a 4240 with 18.4-38 Goodyear Dyna Torque radials. The recommended pressure rating is 12 psi if I remember right. I am running them with 18 psi and they still look too squatty (without a load) to me. What is a safe pressure to run them with out damage? I worry as they get older they may crack from the squattiness. Thanks.
Tx Jim
PostPosted: Wed Dec 11, 2013 6:24 am    Post subject: Re: tire pressure for 18.4-38 Reply to specific post Reply with quote
Lower radial tire pressure gives the tire a larger foot print which means better traction and ride. 12-18 psi is fine. Even lower pressures are fine. Rear tractor loads on 3 pt have a bearing on tire pressures.
buickanddeere
PostPosted: Wed Dec 11, 2013 12:05 pm    Post subject: Re: tire pressure for 18.4-38 Reply to specific post Reply with quote
Why try to 2nd guess the engineers that designed the tires ? They spent thousands of hours and hundreds of thousands of dollars designing and testing those tires. How does somebody stand there in the tractor shed figure that they can do better?
Eric in ky
PostPosted: Wed Dec 11, 2013 12:33 pm    Post subject: Re: tire pressure for 18.4-38 Reply to specific post Reply with quote
I keep 22 lb psi in my rear 18.4X38's. Firestone tubeless
radials.
Ken11487
PostPosted: Wed Dec 11, 2013 7:08 pm    Post subject: Re: tire pressure for 18.4-38 Reply to specific post Reply with quote
I run 12 psi in my 18.4 38 on my 4240.firestones.
T in NE
PostPosted: Sat Dec 14, 2013 6:00 pm    Post subject: Re: tire pressure for 18.4-38 Reply to specific post Reply with quote
Michelin 18.4-42s call for 24 PSI but even under a Steiger they are way too hard at that pressure, even with 500 gallons (at 11 pounds per gallon) hanging on the front of it.
