185
acman220
PostPosted: Wed Dec 11, 2013 9:37 am    Post subject: 185 Reply to specific post Reply with quote
I have a 185 nd I use it all the time.this past winter using it to blow snow it got a funny noise in the transmission in reverse nd used it this summer cutting hay nd now it jumps out of third gear when going down hill. Any suggestions
Ed S. (IL)
PostPosted: Wed Dec 11, 2013 9:45 am    Post subject: Re: 185 Reply to specific post Reply with quote
No links for you, but if you search a bit, you'll find plenty on problems with the transmissions in this series of AC tractor. I have a gas 190, and was not aware when I bought it, but thankfully seem to have gotten a "good" one, or at least one that was repaired before I got it. Jumping out of third going downhill is a symptom of the problem.
From what I remember reading, repair involves tearing into the transmission and welding up/grinding or replacing some components to restore original tolerances. Don't remember the details tho.
es
BigMarv1085
PostPosted: Wed Dec 11, 2013 4:21 pm    Post subject: Re: 185 Reply to specific post Reply with quote
Got a 180 and a 185 sitting in front of the shop that both jump out of 3rd and 4th. No sign of a brake on them at all. It cost $6000 to redo a 190 about 20 years ago.
cole in mo.
PostPosted: Wed Dec 11, 2013 4:55 pm    Post subject: Re: 185 Reply to specific post Reply with quote
You can pull the shifter cover off and take a look inside. Third is the second gear from the front, you can see the sync type lugs and tell how much they are worn, same with the other gears. You might see a bent shifter fork too, But to get the top to come off, shift it into 2nd gear first, leave it in that position for reinstall.
RachelD
PostPosted: Sat Dec 14, 2013 6:22 am    Post subject: Re: 185 Reply to specific post Reply with quote
6000 HOLY CRAP !usually 2 grand catches it !
alliss
PostPosted: Wed Dec 25, 2013 11:41 am    Post subject: Re: 185 Reply to specific post Reply with quote
I replaced the detent spring and ball ,on a 175, and it helped
