MS250 again
Goto page 1, 2  Next
woodbutcher
PostPosted: Mon Dec 16, 2013 8:09 am    Post subject: MS250 again Reply to specific post Reply with quote
I'm still trying to get my Stihl saw to run. When I posted before, I was able to solve the trigger lock problem with the pics that were posted in this forum. I've had this saw for 15 years of moderate use. I thought I knew how to start it. But, today it is about to wear me out. I can usually set the choke and pull the rope. It will fire on the second pull, so I set it to half-choke. Then it will start with one or two more pulls. Today, the full-choke setting works as expected, but then when I pull on half-choke, the rope jerks out of my hand. It seems like I'm pulling against compression. Multiple attempts have given me a bruised left wrist where the rope handle hits me when it jumps out of my right hand. Is anybody familiar with this situation? Am I doing something wrong?
Butch
Billy NY
PostPosted: Mon Dec 16, 2013 8:42 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
I've had bouts with hard starting with a '02 vintage MS390, which I think is in the same family 250,290 310, might not be but, there are some things I can think of that may or may not apply. Is this a cold start?
That might be a fuel line, not sure about the impulse line, but mine had a bad fuel line for awhile, runs/stalls, hard starting and any combination of similar problems.
When hot, I have on occasion, flooded it, thinking it cooled enough to have to choke or half choke, 2nd position on lever, and believe in those instances it was flooded, let it sit for a few minutes it will fire up. I realize its better to see if it will start no choke, then use the choke if no dice, after its been run, depends on the temperature, sometimes it cools right off and its a cold start, they are fussy that way or so mine is.
If you have to pull that many times on one of these, from my experience there is a problem.
Best case, no decompression on mine, with a clean air filter, no issues with spark plug,fuel lines or what have you, from cold, full choke, one pull, it should fire, maybe 2 if its sat awhile. from that first pull, I have been able to move the lever to the 2nd position, kept it running, then squeezed the trigger and worked the throttle, most times it cuts out, move the lever, pull and it does the same, and will keep running. Seems as that air filter,(and it does have an intellicarb) fills with particulates, its does take more to start. This one has been temper-mental with starting, and still cuts out sometimes on the descending side of the throttle, meaning, after a cut or some useage, even revving it a bit, it winds down it will cut out, like if you hit a switch, obviously fuel related, after a new fuel line was installed, sometimes you can move it, work the trigger, it will run, might just be the pick up in the tank, the position, you can make a wire hook to pull that and check the screen, I keep on in my saw tool box. One thing I am not impressed with is the barbed plug connecter, that is of some kind of spring steel and penetrates the plug wire to the coil or ignition module, that I always suspected the connection on this type, could be a problem.
I'll know soon as mine is going to be completely disassembled, have all new OEM plastic for it, and will be putting that on, replace fuel line impulse line, see if there is another ignition wire/plug connecter for it. I like the saw for the most part, plenty of power, I try to take care of it mechanically, but aesthetically from use and not having a case it shows, hopefully these problems are sorted out. I do recall it just seems to start and run better with good service and maintenance, performs great, but I won't lie, it has given me some trouble, like hard starting at times.
woodbutcher
PostPosted: Mon Dec 16, 2013 9:35 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
Thanks, Billy. Yes, it does this on cold starts, but I haven't been able to get it to run, so it might do it on warm starts also. But, I believe that if I could get it to run, a good warm-up might solve the problem. I pulled the plug, and there was more fuel around the base than I thought there should be, but the electrode was dry. Maybe it is flooding. When I try to drop-crank with the choke off, it still won't turn the crank. It's like I'm working against compression.
Butch
Dean
PostPosted: Mon Dec 16, 2013 9:41 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
Sounds badly flooded.
Bull the plug and pull it through quickly multiple times to clear the cylinder and crankcase.
Properly clean the plug or replace.
Dean
D beatty
PostPosted: Mon Dec 16, 2013 9:58 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
My MS250 didn't want to start this fall doing just about the same thing. I changed plug ,air filter and washed out fuel tank and replaced fuel filter. The saw runs fine now but has always been a hard starter with on believable compression and it ripes rope out of hands at times.
PJH
PostPosted: Mon Dec 16, 2013 10:17 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
I have two Stihl saws, both older than yours (021) (039) and since they were brand new, they required 12 pulls fully choked before they would fire. Then I "half" choke it and it runs good. They'll start first pull all day long, after this initial hassle. Even the next day will only require two or three pulls for first start, but leave them set for a week and it's 12 pulls all over again. The dealer begs me to bring them up so he can "fix" them, but they run perfect when they finally start, and I can live with it.
So - like Dean sez - it may be flooded, or it may need the snot cranked out of it on full choke 'til it decides to fire.
You've already tried a new spark plug?
kris Jensen
PostPosted: Mon Dec 16, 2013 10:41 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
I have a Poulan woodshark that acts the same way. It is very hard to start. once started runs and cuts fine. restarts easily once I get it going. finally took it apart. cleaned carb, air filter, took out spark plug, heated the plug and cleaned it, heated the piston chamber,(little propane torches work well sometimes) still no start, took apart again and really cleaned and found that primer bulb was bad, replaced, made sure the fuel lines were clean, et voila, c'est mangifique, it started on the second pull.
Billy C.
PostPosted: Mon Dec 16, 2013 10:47 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
I had a 250 with the same problem--so much compression I got to where I couldn't start it. I solved the problem by selling it and buying a MS250C with the easystart system. Best move I ever made. Just gently pull on the rope until the spring winds up and the saw starts. I can't even use it now because of Pacemaker, so I may sell it. By the way, both heart doctor and manufacturer (Medtronics) told me not to use GAS POWERED CHAIN SAW.
Billy NY
PostPosted: Mon Dec 16, 2013 11:57 am    Post subject: Re: MS250 again Reply to specific post Reply with quote
That sounds odd, well for the discussion here, has to be more to this, if its straight up pulling hard like you say and can't get it to run. Well you have fuel it seems. Its odd, because typically, thats how these seem to start, most times, you'll get it to fire on full choke, mover lever, but not squeeze trigger, and like you say 1-2 pulls it is running, thats how mine is, and it will start after sitting for months, I use Stihl oil in the fuel and some startron, the latter could be snake oil, but it seems to work, I'm on the 2nd fuel line, so I'll see if using that prevented the alleged ethanol/alcohol problem with fuel line material, these do get hot enough, I have to believe over time or use, that may also dry a fuel line out and make it fracture like mine did.
I have to wonder if so much fuel is getting in its vapor locked or hydraulic locked, don't even know if that is possible, I've never heard of this on one of these saws, and if its in running condition, no problems with the piston or cylinder, that is odd, something to learn here, hopefully someone can help here that has expertise, they are not the easiest to pull over, I cannot put my foot in the handle and do it on the ground, I always start it waist high, chain brake on and bar pointed away, for me its safer and easier, my friend has the decompression on the newer MS 360, a nice feature, but mine at 64CC is still not too bad, seems the air filter plays a role in this, I always clean that with compressed air, split in half and carefully blow out the particulates, you get a lot of that from dead dry wood, vs live or trees that have moisture, chips vs straight up dust.
D beatty
PostPosted: Mon Dec 16, 2013 12:06 pm    Post subject: Re: MS250 again Reply to specific post Reply with quote
Billy c. I think that also goes for gas powered weadeaters.
EricB
PostPosted: Mon Dec 16, 2013 12:13 pm    Post subject: Re: MS250 again Reply to specific post Reply with quote
On older well used saws it's also important to clean carbon out of the muffler (or buy a new one if it can't be disassembled) in order to maintain the right amount of resistance for fuel mixture/compression.
Billy C.
PostPosted: Mon Dec 16, 2013 12:32 pm    Post subject: Re: MS250 again Reply to specific post Reply with quote
According to the people I talked with at Medtronics gas powered weedeaters, leaf blowers and push lawn mowers are OK. Doesn't make sense to me.
D beatty
PostPosted: Mon Dec 16, 2013 12:42 pm    Post subject: Re: MS250 again Reply to specific post Reply with quote
That seams funny because some weedeater have more viberation than a chainsaw, Years ago I had a poulan weedeater and in manual it said not to use it for more than 20 minutes at a time. I know if you ran it a 1/2 hour straight your arms and hands were tingling.
Billy NY
PostPosted: Mon Dec 16, 2013 12:59 pm    Post subject: Re: MS250 again Reply to specific post Reply with quote
How'd I forget that, LOL ! yes very true, I have checked mine periodically, its never been loaded up, or ever needed cleaning, but that is going to vary by user and it does not look to difficult for that to happen, it would certainly cause problems. For some of these saws in that family, there is a modification that opens up the exhaust ports, as well as adjusting the carburetor, and checking with a small engine tachometer to insure you stay within the safe rpm range, so it seems they are restricted for emissions already, unlike those built outside of the U.S or exported, supposed to make them run better and last longer.
woodbutcher
PostPosted: Mon Dec 16, 2013 1:55 pm    Post subject: Re: MS250 again Reply to specific post Reply with quote
Thanks, Billy. I may have to do the same.
Butch
Goto page 1, 2  Next
Page 1 of 2
