Super A Hydraulic Fluid
asyrp43
PostPosted: Mon Jan 06, 2014 7:14 am    Post subject: Super A Hydraulic Fluid Reply to specific post Reply with quote
While repainting my Super A I'm decided to replace
the temp gauge for the touch control. I didn't
realize it would still be under presser so when I
pull the wire out the fluid went everywhere! Now
that it's all drained out I need to replace it.
I"m sure it needed to be replaced anyway. My
question what do I need to replace it with and how
much? I looked through my operators manual but
it didn't give any info other than how to operate
the touch control system.
Thanks!
Allen
DeltaRed
PostPosted: Mon Jan 06, 2014 7:50 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
It only takes a gallon or so.The amount will be listed in Capacitys/Specification section of the Owners manual.Use regular Hydralic oil.'Hi-tran'(or equivalent),or 10 wt nondetergent motor oil will also work.
Super A
PostPosted: Mon Jan 06, 2014 7:51 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
I use Hy-Tran (I believe it's actually called Hy-Tran Ultra now) from caseIH. Most people tell you any good hydraulic fluid will work but I prefer Hy-Tran.
Al
asyrp43
PostPosted: Mon Jan 06, 2014 7:54 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
Thanks....I just found an old metal jug of IH Hy-tran in the back of the barn. But I better buy a new can of it.
Thanks DeltaRed....I'll take a look at my manual again. I was looking in the wrong section.
-Allen
KevinBfromIllinois
PostPosted: Mon Jan 06, 2014 8:21 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
Can't remember for sure but my Super C has a screen filter in side of the reservoir where the touch control cable goes in I think the Super A will also have this might want to take out a clean before refilling.
asyrp43
PostPosted: Mon Jan 06, 2014 8:23 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
If it did it was probably blown out with the pressure. I'll look around on the floor.
TractormanNC
PostPosted: Mon Jan 06, 2014 8:48 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
The screen that kevin refers to is held in by 4 bolts in the plate from which you removed the temp gauge sending bulb. Be careful when pulling out the screen as they are fraigle. So far as I know only available from CIH and $$$$$. Buy a new gasket or be prepared to make a new one. Don't ask how I know this.
Super A
PostPosted: Mon Jan 06, 2014 9:28 am    Post subject: Re: Super A Hydraulic Fluid Reply to specific post Reply with quote
asyrp43, if you want to get rid of that can, and if it's in reasonably good shape, let me know. My email's open.
thanks!
Al
