Magnetic Heaters
IAtractorKid
PostPosted: Mon Jan 06, 2014 10:28 am    Post subject: Magnetic Heaters Reply to specific post Reply with quote
Hey guys! So my 400 sits outside all winter, I have a coolant heater on it that runs on a timer. Tractor starts right up and runs fine, but the hydraulics (both factory live and PTO) are pretty slow until it gets warmed up completely. Wondering if I can stick a couple magnetic block heaters on the reservoirs with risk of overheating the fluid and deteriorating it. I see they sell both 200 and 300 watt units that say they provide 300-400 degrees of heat. Thanks!
Janicholson
PostPosted: Mon Jan 06, 2014 10:36 am    Post subject: Re: Magnetic Heaters Reply to specific post Reply with quote
They will work fine, Only one needed. The oil will circulate from convection in the tank. Putting an old jacket over the reservoir will also help keep it toasty. I use one on a Nissan Truck to get the oil warm. Put it on a cold proof timer to allow it to do its job for 2 hours. Jim
ih_bug
PostPosted: Mon Jan 06, 2014 12:10 pm    Post subject: Re: Magnetic Heaters Reply to specific post Reply with quote
like jim said except my experience has been more like 8-10 hours. depends how cold I guess.
Russ from MN
PostPosted: Mon Jan 06, 2014 8:01 pm    Post subject: Re: Magnetic Heaters Reply to specific post Reply with quote
I have a 200 watt and it will get a 5 quart oil pan warm to the touch in 3 hours, in a building out of the wind. Outside ?
36F30
PostPosted: Mon Jan 06, 2014 8:24 pm    Post subject: Re: Magnetic Heaters Reply to specific post Reply with quote
On a sheet metal pan they work in a few hours. On a cast housing they take much much longer.
KAT'S makes immersion heaters that replace drain plugs that heat the oil directly.
ih_bug
PostPosted: Tue Jan 07, 2014 12:36 am    Post subject: Re: Magnetic Heaters Reply to specific post Reply with quote
thought maybe I should clarify . The 2 places I have used one. one is a 7 gallon steel hydraulic tank outside . the heater works really good but takes 10 hrs. will throw a blanket over the tank next time good idea. the other is a cast iron oil pan with 10-12 liters of oil in it outside again. minus 20 and 30 Celsius.
