Wd45 with loader value
AllisG
PostPosted: Thu Jan 09, 2014 5:06 pm    Post subject: Wd45 with loader value Reply to specific post Reply with quote
Found this on Craigslist for $750, has newer rears and weights plus loader only thing is the engine is locked up. Is it a salvageable project??!
[img]http://forums.yesterdaystractors.com/photos/mvphoto2434.jpg[/
AllisG
PostPosted: Thu Jan 09, 2014 5:14 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Hope it works this time
DiyDave
PostPosted: Thu Jan 09, 2014 5:45 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Rear tires wheels and weights are worth almost that! Only way to
see, is to swing at it!
old
PostPosted: Thu Jan 09, 2014 7:15 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
A whole lot depends on why the engine is locked up. If it has gotten rain water in the engine then yes the engine is likely to be needing a rebuild but what I saw if parted out would bring twice the asking price if you can handle selling things a little at a time. Now if it is locked up due to sitting good chance a ATF treatment will fix it
AllisG
PostPosted: Thu Jan 09, 2014 7:44 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Well the owner got sick 10 years ago And so he parked it, but there looks to be atleast a can covering the exhaust so iam hoping its a soft lock
old
PostPosted: Thu Jan 09, 2014 8:48 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
A number of years ago I picked up a Farmall H that we had to cut a tree away from it to pull it out of where it was. The guy said it had sat there for at least 10 years that the knew of. It had a can over the exhaust. We loaded it up and took off. I filled the cylinders with ATF before I unloaded it. And in less then 48 hours the engine was freed up and running
JMS/.MN
PostPosted: Thu Jan 09, 2014 9:19 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Before you determine a price, determine if it really is a WD45, by serial number. 146,607 or above. Loader might be worth a couple hundred bucks, but I bought a loose WD45 a few years ago for $500.
BushogPapa
PostPosted: Fri Jan 10, 2014 8:32 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Good rubber on the back.
That loader will lift a whole Beef when butchering.
Might have 14.9x28" (old 13x28 size)..
Ron.
BushogPapa
PostPosted: Fri Jan 10, 2014 8:34 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Steering it with a good load in the Bucket builds "Character" AND Forearms..!!!
Ron.
AllisG
PostPosted: Sat Jan 11, 2014 12:31 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
BushogPapa wrote:
(quoted from post at 21:34:26 01/10/14)
Ron.
It has power steering on it too
BushogPapa
PostPosted: Sun Jan 12, 2014 7:30 pm    Post subject: Re: Wd45 with loader value Reply to specific post Reply with quote
Sounds like a good one to find...!
