cylinder head
breese
PostPosted: Mon Jan 13, 2014 8:03 pm    Post subject: cylinder head Reply to specific post Reply with quote
This message is a reply to an archived post by Pajamafied John on June 06, 2012 at 15:56:11.
The original subject was "Re: cylinder head".
I replaced the pistons (and sleeves/rings) in my 1945 2N. The top of the pistons were slightly domed and touched my cylinder head (not bolted down, no gasket).
I'm concerned I may have removed 'too much' cylinder head material as my max compression is only 40 PSI across all pistons. Root cause may lie elsewhere (and I'm troubleshooting that for now) - just curious if removing too much cylinder head metal might be my problem; your thoughts?
JMOR
PostPosted: Mon Jan 13, 2014 9:18 pm    Post subject: Re: cylinder head Reply to specific post Reply with quote
Breese wrote:
(quoted from post at 00:03:16 01/14/14) This message is a reply to an archived post by Pajamafied John on June 06, 2012 at 15:56:11.
Won't make that kind of difference....you have other problems!
HCooke
PostPosted: Tue Jan 14, 2014 5:25 am    Post subject: Re: cylinder head Reply to specific post Reply with quote
" my max compression is only 40 PSI across all pistons"
Could be valve timing. Check timing mark on crank gear and cam gear.
teddy52food
PostPosted: Tue Jan 14, 2014 7:07 am    Post subject: Re: cylinder head Reply to specific post Reply with quote
Do anything to the valves? Head is not your problem.
ford4
PostPosted: Wed Jan 15, 2014 5:15 pm    Post subject: Re: cylinder head Reply to specific post Reply with quote
Very comon problem. There is little clearance between the head and piston and machine work was not very precise back in the 40's and 50's. Therefore removing material from the head and/or block on one engine may be ok while the next one may cause interference problems. There are shims available in different thicknesses to compensate for this. The shim must be against the block and sprayed with copper coat. I have used them and don't worry, they do not leak.
