Update on 8N quitting while brush hogging
Richard G.
PostPosted: Tue Jan 14, 2014 6:37 am    Post subject: Update on 8N quitting while brush hogging Reply to specific post Reply with quote
A couple of weeks ago I posted about my 52 8N quitting while brush hogging. It has been so wet, I have not been able to do much of anything with the tractor until yesterday. Checked the distributor and found the point gap had closed up to about .015. I guess the rubbing block had worn some. Cleaned and set points to .025 and it seems to be doing well. Will know more when it gets dry enough to get back on the ground with the hog.
Thanks, Richard in NW SC
J. Everett
PostPosted: Tue Jan 14, 2014 7:23 am    Post subject: Re: Update on 8N quitting while brush hogging Reply to specific post Reply with quote
How does it run when set at .025? The normal setting is in fact .015 so you may have dirty plugs and or a week spark...something going south anyway, better look things over.
JCinKY
PostPosted: Tue Jan 14, 2014 7:32 am    Post subject: Re: Update on 8N quitting while brush hogging Reply to specific post Reply with quote
J. Everett wrote:
(quoted from post at 08:23:04 01/14/14) How does it run when set at .025? The normal setting is in fact .015 so you may have dirty plugs and or a week spark...something going south anyway, better look things over.
52 should be a side mount with a point gap of .025.
Front mount point gap is .015.
Richard G.
PostPosted: Tue Jan 14, 2014 8:13 am    Post subject: Re: Update on 8N quitting while brush hogging Reply to specific post Reply with quote
It is running great and the 52 is supposed to be set at .025.
Richard
old
PostPosted: Tue Jan 14, 2014 8:15 am    Post subject: Re: Update on 8N quitting while brush hogging Reply to specific post Reply with quote
0.015 is correct only for the front mount distributor. The side mount came out in April or May of 1950 and the correct point gap for the side mount is in fact 0.025
