no gas flow gas
Constance Barnette
PostPosted: Tue Jan 14, 2014 10:55 am    Post subject: no gas flow gas Reply to specific post Reply with quote
Help! I am trying to revive my 9N that has been setting for about three years. New battery, new plugs, new gas, new fuel bowl & fb gasket. When I crank the motor the gas is not flowing to the carb. I have turned on the gas and the fuel bowl is full but gas is not going through to the copper gas tube to the carb. How do I fix this problem? Any help will be greatly appreciated.
HCooke
PostPosted: Tue Jan 14, 2014 11:02 am    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
There are three filters, one is in the carb elbow. Disconnect the fuel line there and see if you have gas flow. If so your blockage is in the elbow filter. If still no flow check the two filters in the valve at the tank.
http://www.yesterdaystractors.com/Ford 9N_Carburetor Elbow and Strainer_9N9553.html
old
PostPosted: Tue Jan 14, 2014 11:20 am    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
Take the line off the carb. Turn on the gas. If you have flow there turn the gas off and remove the elbow in the carb and make sure it is not clogged up. It should have a screen filter which commonly clogs and causes problems. If it is not clogged then pull the carb drain plug and make sure you have a steady flow of gas out of that. If no gas good chance the float is stuck closed and the carb will need to be opened up and probably rebuilt
souNdguy
PostPosted: Tue Jan 14, 2014 1:17 pm    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
pull drain to carb.. anything. if not check the filters these guys mentioned.
Royse
PostPosted: Tue Jan 14, 2014 4:01 pm    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
Not much to add to the good advice you already got, except
that the line going to the carb should not be copper.
Copper will crack with vibration. It should be steel.
Standard 1/4 inch steel brake line works great and has the right
fittings on it. If your local auto parts store sells it in 30 inch
lengths like most do you won't even need to cut it.
Just bend it, attach it and go. Cheap and easy peace of mind.
souNdguy
PostPosted: Tue Jan 14, 2014 4:49 pm    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
yup.. and bender form harbor freight is 3.99!
howdy1960
PostPosted: Wed Jan 15, 2014 3:31 pm    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
As Royce said the copper line will crack and I attest to it. I have the steel line awaiting me getting a 'roundtuit' (I know I have one here someplace)
Colin King
PostPosted: Wed Jan 15, 2014 3:40 pm    Post subject: Re: no gas flow gas Reply to specific post Reply with quote
I have seen situations where the fuel flow will stop if the sediment bowl is over tightened. I don't know why, and I probably should...but maybe this will help.
I doubt you have a copper fuel line, unless you installed it yourself. Copper will not last long.
Post back with your results.
Colin, MN
