How to add aux hydro valves jd 2130
Fort steele tractors
PostPosted: Tue Jan 14, 2014 5:24 pm    Post subject: How to add aux hydro valves jd 2130 Reply to specific post Reply with quote
I'm looking at a used 2130 tractor with 146 loader. The tractor does not currently have hydraulic ports to the rear.
What are my choices to add one set of hydraulic couplers and control valve to the rear. How costly. Or should I just wait tilli find a tractor already set up?
Thanks, ask on the lot for the tractor is 10k thanks
Cliff Nelson
PostPosted: Tue Jan 14, 2014 8:55 pm    Post subject: Re: How to add aux hydro valves jd 2130 Reply to specific post Reply with quote
Price will depend on if you want OEM valve and couplers or if you are ok with mounting a simple spool valve. Spool valve would probably run $300-400 by the time you buy hoses and couplers. A dual spool valve would not be much more if you think you will ever have a need for 2 valves. Original Deere valve setup you could get used from a salvage yard but will cost more.
buickanddeere
PostPosted: Wed Jan 15, 2014 2:22 pm    Post subject: Re: How to add aux hydro valves jd 2130 Reply to specific post Reply with quote
Lots of worn out Dubuques and Mannheims in the salvage yards with pin holed sleeves and ruined engines.
SCV is a bolt on swap.
Assuming the loader is plumbed to an independent joystick?
10 Grand for the setup sounds plenty expensive ?
