JD 5020 injector rubber hose
37chief
PostPosted: Tue Jan 14, 2014 6:09 pm    Post subject: JD 5020 injector rubber hose Reply to specific post Reply with quote
There is a rubber sleeve over the end of the injector to connect the injector to by pass fuel to the tank. What is this rubber sleeve called? I can't find anything on the internet. If I had the correct name I probably could find the part. Thanks Stan
matthies
PostPosted: Tue Jan 14, 2014 6:18 pm    Post subject: Re: JD 5020 injector rubber hose Reply to specific post Reply with quote
Its called a boot, part no. R34765. chris
Dieseltech
PostPosted: Tue Jan 14, 2014 7:05 pm    Post subject: Re: JD 5020 injector rubber hose Reply to specific post Reply with quote
Stanadyne part # 16390 also.
Dieseltech
PostPosted: Tue Jan 14, 2014 7:08 pm    Post subject: Re: JD 5020 injector rubber hose Reply to specific post Reply with quote
Forgot to mention, 16390 is tee style, if straight # is 16165
Mike M
PostPosted: Wed Jan 15, 2014 6:47 am    Post subject: Re: JD 5020 injector rubber hose Reply to specific post Reply with quote
Do you think that if you had a set of them that were NEW on the shelf they could still be good after many years ? Don't know what kinda shelf life to expect from them ? I have a set of 6 here for emergencies but they are old.
D-
PostPosted: Wed Jan 15, 2014 1:24 pm    Post subject: Re: JD 5020 injector rubber hose Reply to specific post Reply with quote
Probably will be OK. They break down from fuel, possibly heat might add to breakdown.
