zae front end
nl00sb
PostPosted: Mon Jan 20, 2014 5:27 pm    Post subject: zae front end Reply to specific post Reply with quote
I have a zae and have single front assembly I want to put on it what is involved in the swap from adjustable wide to single front thanks neal
T.R.K.
PostPosted: Tue Jan 21, 2014 5:57 pm    Post subject: Re: zae front end Reply to specific post Reply with quote
1. Support the tractor. There is a nice flat spot under the rear of the oil pan.
1. Disconnect the steering shaft and any electric wiring, if present.
2. Drain and remove the radiator. I think there are 2 bolts behind, one in front, one up from the bottom on each side.
3. Support the front end. Six bolts hold it to the engine. You will probably have to raise the engine about 2-3 inches for the front crank pulley to clear so you can move the front bolster away.
4. Reverse the procedure to reassemble.
1939
PostPosted: Wed Jan 22, 2014 4:58 pm    Post subject: Re: zae front end Reply to specific post Reply with quote
location i mite be interested in wide front
nl00sb
PostPosted: Mon Jan 27, 2014 2:44 pm    Post subject: Re: zae front end Reply to specific post Reply with quote
Rochester NY whole tractor can be purchased with front end on it aswell or separate
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
