Injection pumps
Goto page 1, 2  Next
gtx1967jewison
PostPosted: Wed Jan 22, 2014 7:30 pm    Post subject: Injection pumps Reply to specific post Reply with quote
Can anyone tell me if the Bosch/scintilla injection pumps on a 720/730 are the same as on an 820/830?
Thanks!
J
buickanddeere
PostPosted: Wed Jan 22, 2014 7:50 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Yes and no.
The 70,80 and green Dash 820 used 10mm pumps. The 720,730,black dash 820, 830 and 840 used 13mm pumps.
Injector tips varied with 5 and 6 hole units with 10 and 12 thou orifices.
JLF
PostPosted: Thu Jan 23, 2014 6:28 am    Post subject: Re: Injection pumps Reply to specific post Reply with quote
The pumps are the same except for the plunger followers on the bottom of the pump.
gtx1967jewison
PostPosted: Thu Jan 23, 2014 5:00 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Thanks! Do you happen to know anything about the 15mm
ones used in marine engines? Like where to find them Smile
buickanddeere
PostPosted: Thu Jan 23, 2014 8:57 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
I have wondered is the injection pump elements from old time large displacement industrial diesels would bolt into the Deere ?
gpuller
PostPosted: Fri Jan 24, 2014 10:40 am    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Gtx1967jewison wrote:
(quoted from post at 18:00:46 01/23/14) Thanks! Do you happen to know anything about the 15mm
They put 2 cyl diesels in boats?
There are guys out there that make what your looking for, but you'd better have some cubes to burn the fuel they deliver. 13.5mm's have to be weaned way down for a 720/30.
buickanddeere
PostPosted: Fri Jan 24, 2014 1:33 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
I've wondered if the Z or C pump elements may be a drop in upgrade for a two cylinder Deere ? Don't know if JD uses the 12mm or 15mm stroke pump?
http://www.oldengine.org/members/diesel/injection/Bryce4.htm
I updated an A pump on a Petter diesel from 7mm to 8mm. Limited the 8mm delivery volume to the same as the 7mm's volume. Engine runs better with the injection event ending while the piston is higher in the bore.
gtx1967jewison@yahoo.com
PostPosted: Sat Jan 25, 2014 12:14 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Not 2 cylinders, but the pumps were the same design I am
told. I cannot find anyone that will divulge more info, not even
where to go or who/how, nothing. I have a stock R that I just
want more fuel, perhaps a few more horses & a better show at
the pulls. Can I just use 730 pumps & leave my stock
nozzles/injectors/pistons? Or do I need to bore it & change
pistons & injectors ? Any help is greatly appreciated!
J
buickanddeere
PostPosted: Sat Jan 25, 2014 8:40 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Gtx1967jewison@yahoo.com wrote:
(quoted from post at 16:14:51 01/25/14) Not 2 cylinders, but the pumps were the same design I am
J
Stock HP will break the two bearing crank in a R. Best bet is to find a 820 blackdash and build it.
Cam,valve.port, inlet filtration and injection work will make 100+HP at stock rpms.
Gpower
PostPosted: Sun Jan 26, 2014 5:56 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Gtx, drop me a line, I can help you out.
gpuller
PostPosted: Sun Jan 26, 2014 7:53 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Gpower wrote:
(quoted from post at 18:56:11 01/26/14) Gtx, drop me a line, I can help you out.
There you go. Good to see you MO! Gpower can help, he got me set up.
I don't drink the R crank breaking kool-aide. Plenty of high powered R's and nobody has a story to tell?
Gpower
PostPosted: Mon Jan 27, 2014 7:26 am    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Yeah, me either, I know I was "cranking" out 88hp on the dyno at 560-570 pto rpm when the pto gears gave out. Any crankshaft can break.
gtx1967jewison
PostPosted: Wed Jan 29, 2014 8:13 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
THANKS Gpower!
sincerely appreciated, i think i got an email sent off to you
Gpower
PostPosted: Thu Jan 30, 2014 3:31 pm    Post subject: Re: Injection pumps Reply to specific post Reply with quote
Yep, just replied.
Kent Petersen
PostPosted: Sun Feb 02, 2014 6:23 am    Post subject: Re: Injection pumps Reply to specific post Reply with quote
B&D i have heard that storey for years but can't find a body that will say he did have one brake i know a guy that has 2 Rs overboered to 730 pistions turning right at 100 HP and he has never broke acrank
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
