Parts questions???
WW2N
PostPosted: Sat Jan 25, 2014 4:06 pm    Post subject: Parts questions??? Reply to specific post Reply with quote
1952 Ford 8N,I am replacing the lower left arm support shaft can find the part but can't find the Castlelated nut and the nut that holds the swivel ball on the shaft.The swivel ball is shot. Can the weld on lift arm piece be used on the lower shaft support?
souNdguy
PostPosted: Sat Jan 25, 2014 4:15 pm    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
if the weld on arm end works for the implement end.. it will work for the support end. that or you can get another arm..e tc.
on the castle nt. in an emergency.. you can always make one.
i've made castle nuts for tie rod ends plety of times. just takes a vice and a say blade or die grinder / cutoff wheel to notch a nut.. etc.
I'd do that before holding up a project too long if I needed the tractor.
Texas!
PostPosted: Sat Jan 25, 2014 4:59 pm    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Are you looking for the castle nuts using the old Ford part number? Any auto parts/hardware store should have them. You just need the correct thread diameter and pitch such as 7/16"-20 or 1/2"-20.
jon
PostPosted: Sat Jan 25, 2014 5:24 pm    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Just 8 ns has the Castle Nut for $1.05.
Part 356087-S
Bob
PostPosted: Sat Jan 25, 2014 5:42 pm    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Inner castle nut... 3/4"-16 TPI (NF) (NH #351129S) (DEERE #J13155)
Outer nut = 5/8", 18 TPI (NF) (NH #55757S7) (DEERE #14H950)
Should be pretty common Fastenal, or even hardware store stuff, if the local NH or DEERE dealer don't have 'em!
WW2N
PostPosted: Sat Jan 25, 2014 9:38 pm    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Thanks all
WW2N
PostPosted: Sat Jan 25, 2014 9:41 pm    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Good enough.
ASEguy
PostPosted: Sun Jan 26, 2014 4:51 am    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Never even considered doing that. Good tip. I always save good parts like castle nuts, tie rod boots "etc". Learned a long time ago my tool box needed a junk drawer.
Hobo,NC
PostPosted: Sun Jan 26, 2014 5:56 am    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
Bob wrote:
(quoted from post at 05:42:29 01/26/14) Inner castle nut... 3/4"-16 TPI (NF) (NH #351129S) (DEERE #J13155)
Whut he said and to add I don't think the original (inner) was 3/4" but the replacements are check the new pin before you tear into it... The outer is still 5/8....
souNdguy
PostPosted: Mon Jan 27, 2014 6:11 am    Post subject: Re: Parts questions??? Reply to specific post Reply with quote
deffinately. I have coffee cans full of that kind of stuff. just never know when you will need one. even if it is a temp fix till a new part arrives.
