oil slinger on Perkins A4.318
ecar
PostPosted: Mon Jan 27, 2014 5:09 pm    Post subject: oil slinger on Perkins A4.318 Reply to specific post Reply with quote
I'm reassembling Perkin A4.318 and was scanning the
repair manual and it references re-installing oil
slinger between crankshaft gear and front seal. I
am pretty sure don't remember seeing one during
disassembly (then again, I am going senile). I
can't find one in my parts box and I don't see one
in the parts book.
Is there an oil slinger on a Perkins A4.318? I have
a 1981 MF 285.
hymie2lt
PostPosted: Mon Jan 27, 2014 5:53 pm    Post subject: Re: oil slinger on Perkins A4.318 Reply to specific post Reply with quote
Yes there is supposed to be a slinger. Same as on the 1080 and the super 90s, 300 perkins engine. Part number is different however for these two models, 733048m1.
Your part number is 745246m1. Basically a dish shaped piece of iron, fits right in front of the crankshaft gear.
Wayne
ecar
PostPosted: Tue Jan 28, 2014 4:22 am    Post subject: Re: oil slinger on Perkins A4.318 Reply to specific post Reply with quote
thanks.
Is it relatively thin like a washer?
Totally flat?
I think I found the part. I thought it went on something else.
Aleuicius
PostPosted: Tue Jan 28, 2014 5:47 am    Post subject: Re: oil slinger on Perkins A4.318 Reply to specific post Reply with quote
A slinger most often looks like a stamped sheetmetal "fender" washer - though bigger diameter. The center is generally pressed at almost 90 and it's intended to be tight on the shaft and uses centrifugal forces to "sling" most oil/water/etc away from the seal.
hymie2lt
PostPosted: Wed Jan 29, 2014 12:44 pm    Post subject: Re: oil slinger on Perkins A4.318 Reply to specific post Reply with quote
Sorry it took so long to get back to you, I had some E-mail problems here. Also had to find my slinger.
I hope to upload a photo, if I can figure out how to do it.
My slinger is about 4 3/8 inches across. Flat except for the turned up edge.
Has a Perkins part number on it of 33157516 stamped to the other side.
This one is off a Super 90 tractor.
Wayne
ecar
PostPosted: Wed Jan 29, 2014 3:33 pm    Post subject: Re: oil slinger on Perkins A4.318 Reply to specific post Reply with quote
Thanks a lot for the photo Wayne.
I looked everywhere and can't find that part in what I took off the engine. I am starting to think I didn't have one on. I imagine if I didn't use one, I would be more susceptible to a front seal leak.
