ford 455 loader b-hoe~ trans fluid what type?
glenn pyzak
PostPosted: Wed Jan 29, 2014 9:48 am    Post subject: ford 455 loader b-hoe~ trans fluid what type? Reply to specific post Reply with quote
ok, just got it home and need to replace the main trans fluid. What type? is it shared with the rear end? its white and creamy,so I know there is water mixed in. thanks...
greenporsche
PostPosted: Wed Jan 29, 2014 1:02 pm    Post subject: Re: ford 455 loader b-hoe~ trans fluid what type? Reply to specific post Reply with quote
HI,
TSC Hydra-Trans will work fine.. Milky = Water..
Ecnerwal
PostPosted: Thu Jan 30, 2014 5:51 am    Post subject: Re: ford 455 loader b-hoe~ trans fluid what type? Reply to specific post Reply with quote
Anything that meets Ford/NH MC134D spec - which is most but not all universal tractor fluids
Pops1532
PostPosted: Thu Jan 30, 2014 9:22 am    Post subject: Re: ford 455 loader b-hoe~ trans fluid what type? Reply to specific post Reply with quote
Anything that meets the MC134D spec will work. I'd spring for NH Ambra or Mobil 424 instead of the universal stuff at the farm stores....on advice from someone retired from the oil business and a friend that's an engineer for a major equipment manufacturer.
Roy Suomi
PostPosted: Thu Jan 30, 2014 10:31 am    Post subject: Re: ford 455 loader b-hoe~ trans fluid what type? Reply to specific post Reply with quote
Once you get it free of water contamination , You should either cover the top of the transmission or replace the O-rings on the plastic shifter collars right on the shift levers..
T in NE
PostPosted: Mon Feb 10, 2014 3:12 pm    Post subject: Re: ford 455 loader b-hoe~ trans fluid what type? Reply to specific post Reply with quote
That's my advice just based on experience. OR stick with a major name-brand oil that meets spec.
Isn't hy-tran and Ford 143 supposed to play well together now?
