4030 diesel timing pin hole
2SteveWI
PostPosted: Wed Jan 29, 2014 3:41 pm    Post subject: 4030 diesel timing pin hole Reply to specific post Reply with quote
Replacing the Injection Pump on brother-in-laws 4030. The Original one failed @ 13,000 hours. Of course it was 20 below outside. Trying to find the hole for the TDC pin. This a very early 4030, under 4000. According to JDparts.com the pin hole is just under the hole for the Flywheel Turning Tool. Checked his tractor, and cannot find a timing pin hole. Is there an alternate method of finding TDC on this tractor. Thanks Steve.
Tx Jim
PostPosted: Wed Jan 29, 2014 3:44 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
Timing pin hole should be where plug(parts key #14) is located. There were no serial number breaks for the flywheel housing so all tractors should be similar to parts photo.
tim s
PostPosted: Wed Jan 29, 2014 4:05 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
remove the timing window and rotate the engine till the marks line up is another way of doing it...
2SteveWI
PostPosted: Wed Jan 29, 2014 4:12 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
That would be plan B. I was not sure if that would be accurate enough. Have replaced several injection pumps on John Deere's over the years, and this is the first one I have not been able to set at TDC.
Tech 7
PostPosted: Wed Jan 29, 2014 4:28 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
I know its a gasser but the one I have torn down right now did not have a pin hole in the housing. Does have timing mark on crankshaft pulley I know this doesnt help you. This tractor is early (73) and I would wonder at Deere building the rear plate different for diesel or gas
tim s
PostPosted: Wed Jan 29, 2014 4:33 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
I'm kinda with you on that Tech7,,,it may not have a timing hole,, I always use the pump timing marks when I'm just doing a pump, and the cam marks when I'm doing an O/H....
Tx Jim
PostPosted: Thu Jan 30, 2014 3:51 am    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
According to JDparts the same flywheel housing(R51794) was utilized on both gasoline & diesel and only on a 4030 no other models
2SteveWI
PostPosted: Thu Jan 30, 2014 5:11 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
Lined up the marks in the window on the injection pump. Found a mark on front pulley, that lined up with a mark on front cover behind pulley. Initially the mark was buried under a layer of dirt. Probably the same mark used to time a gas engine. Thanks for all the replies. Steve.
tim s
PostPosted: Thu Jan 30, 2014 5:15 pm    Post subject: Re: 4030 diesel timing pin hole Reply to specific post Reply with quote
You did the right thing by finding the marks "before" you pulled the pump,,saved your self a lot of grief....
