Case 630 Hitch Capacity
K-Mo
PostPosted: Mon Feb 03, 2014 9:11 am    Post subject: Case 630 Hitch Capacity Reply to specific post Reply with quote
Does anyone know the lifting capacity (lbs) of the Case 630 Eagle Hitch?
Can't find any reference in the owner's manual or anywhere else.
Thanks,
K-Mo
Adirondack case guy
PostPosted: Mon Feb 03, 2014 3:30 pm    Post subject: Re: Case 630 Hitch Capacity Reply to specific post Reply with quote
What do you want to lift and carry. Lifting #'s at the arms is fare diff., than say a 4B MTA plow, which a 630 will handle well; with 500# of nose weights.
Loren
K-Mo
PostPosted: Mon Feb 03, 2014 5:07 pm    Post subject: Re: Case 630 Hitch Capacity Reply to specific post Reply with quote
Yes, I understand what you mean. I would like to see all 3Pt equipment specify a minimum lift capacity requirement. 2000 lbs at the end of the lift arms and 2000 lbs 4 feet behind the lift arms are two different things. Various tractors I have found lift capacities for, some are surprisingly high, some surprisingly low. I have an old 26 HP, 2350 lb Kubota with a specified lift capacity of 2650 lbs at the end of the lower links.
I have a 7' cultipacker with a straw stitcher. Probably about 1200 lbs.
It would be nice to know what the 630 capacity is.
John Saeli
PostPosted: Tue Feb 04, 2014 12:55 pm    Post subject: Re: Case 630 Hitch Capacity Reply to specific post Reply with quote
When she was new, a 630 would snap a set of 3-16"s up in a heartbeat. 50 years later, & a worn pump, she may not even lift them. The pump condition will be the limiting factor.
