Case 580 C Starts but then stalls
Ram4wd
PostPosted: Mon Feb 03, 2014 4:13 pm    Post subject: Case 580 C Starts but then stalls Reply to specific post Reply with quote
I started my Case today and ran it for a while. It then proceded to stall. I would restart it but it would run at an weak idle then stall. it would then restart again. I changed the diesel fuel filters but it didnt help. I was thinkng there may be ice in the line. I am in NJ. Thanks in advance for any suggestions.
j hikemper
PostPosted: Mon Feb 03, 2014 4:25 pm    Post subject: Re: Case 580 C Starts but then stalls Reply to specific post Reply with quote
Get somme 911 and or seafoam and use sparingly , it is alcohol,so a little dab a do ya ,. assuming it is below freezing in nj ,, and also assuming ,you DO know how to bleed the filters? and air from typical diesel motors ,, and you can loosen a few lines at the injectors and crank the air thru ,, ,, let us know how it goes
chuck machinist
PostPosted: Mon Feb 03, 2014 5:45 pm    Post subject: Re: Case 580 C Starts but then stalls Reply to specific post Reply with quote
Myron ,
Thanks for the link.Thats only the second LP 400 that I have seen. Chuck
Dieseltech
PostPosted: Mon Feb 03, 2014 8:09 pm    Post subject: Re: Case 580 C Starts but then stalls Reply to specific post Reply with quote
If filters are OK, and flow to injection pump inlet is good the pump may need repair. Test by loostening the two timing cover screws so fuel can leak out. If it runs better without dieing then the injection pump needs serviced soon before much more expensive damage occurs. Just repaired an AC 185 pump for the same trouble.
