Author |
Message |
Kollebo Regular
Posted: Tue Feb 11, 2014 12:19 pm Post subject: 4440 hi-lo trouble |
Hello
I just mounted à new hi lo clutch
And. When i shift to high the gear goes in LO
And When i shift to LO the gear is goding to high
So My shift pantern isnt right anymore
I have never driven the traktor before because i baught it
When it was broken.
Any ideas? |
Back to top |
jdpuller4440 New User
Posted: Tue Feb 11, 2014 12:23 pm Post subject: Re: 4440 hi-lo trouble |
Your 2 speed shaft in 180 degrees off. You can split it to fix it, or grind the weld off of the tab on the outside of the shaft, turn it 180 degrees and reweld it. I've done it several times on pulling tractors to modify the linkages. |
Back to top |
Kollebo Regular
Posted: Tue Feb 11, 2014 12:29 pm Post subject: Re: 4440 hi-lo trouble |
But the tab is pointing downwards. That should be right?
Or should it point up? |
Back to top |
Posted: Tue Feb 11, 2014 12:47 pm Post subject: Re: 4440 hi-lo trouble |
on ours, when the tab is at 8 o'clock, it's in 3rd, and at 7 o'clock it's in 4th
does that help? |
Back to top |
Kollebo Regular
Posted: Tue Feb 11, 2014 12:50 pm Post subject: Re: 4440 hi-lo trouble |
My rap is Aldo at 7 and 8 but the gears is incorrect When i lock at the shiftpattern |
Back to top |
Posted: Tue Feb 11, 2014 1:23 pm Post subject: Re: 4440 hi-lo trouble |
are you sure you have a 4440 2 speed? They were a direct-overdrive. The 4440, 4450, 4455, were the only ones to use the direct-overdrive. The replacement gears for the planetary on the s speeds are a helical cut gear, whereas the original 4440's were straight cut gears.
The rest of the 2 speeds were underdrive-direct like the 4030, 4230, 4430, 4630, 4040, 4240, 4640 used.
A 4430 2 speed installed in a 4440 would slow it down, and the gears would shift backwards. |
Back to top |
Kollebo Regular
Posted: Tue Feb 11, 2014 1:45 pm Post subject: Re: 4440 hi-lo trouble |
Aha. I have baught it fr.o.m. À 4040 |
Back to top |
Posted: Tue Feb 11, 2014 4:02 pm Post subject: Re: 4440 hi-lo trouble |
do you have or have access to the old 2 speed? Drop me an email.
bl4440 at schallertel dot net |
Back to top |
Kollebo Regular
Posted: Tue Feb 11, 2014 9:02 pm Post subject: Re: 4440 hi-lo trouble |
Yes i have the old one here in My shop |
Back to top |
