Switching from a mag to distributor
JS Sleds
PostPosted: Wed Feb 12, 2014 11:26 am    Post subject: Switching from a mag to distributor Reply to specific post Reply with quote
I'm switching from a mag to a distributor on this 206 engine . Do I have to change the drive? Thanks for the advice on the crank installation. Jeff
molnegb
PostPosted: Wed Feb 12, 2014 12:52 pm    Post subject: Re: Switching from a mag to distributor Reply to specific post Reply with quote
Distributor shaft drive gear has to be changed for distributor application.
T.R.K.
PostPosted: Wed Feb 12, 2014 6:50 pm    Post subject: Re: Switching from a mag to distributor Reply to specific post Reply with quote
You will need to change both the distribuitor gear and the mating drive gear on the camshaft. For battery igntion, both gears will need to have 16 teeth.
They had 12 and 24 teeth for the magneto.
You may have to change the socket on the end of the distribuitor shaft to accept the distruibuitor too.
SWMolines
PostPosted: Thu Feb 13, 2014 4:07 am    Post subject: Re: Switching from a mag to distributor Reply to specific post Reply with quote
There are distributor drives available that directly replace a magneto if you are not concerned about keeping it original. The ones used on Farmalls and AC tractors have been used on MM"s.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
