Spark plug threads twisted off in head
Goto page 1, 2  Next
LarryNMO
PostPosted: Sun Feb 16, 2014 6:00 pm    Post subject: Spark plug threads twisted off in head Reply to specific post Reply with quote
Hi guys, I know this is a tractor site, but maybe I can get some help with this problem. I've got a 150hp outboard mercury engine that has the spark plug threads twisted (broken off) in the head. It was being installed to specs (torque) when it broke off. Is there a better way other than an easy out, haven't attempted that yet but just looking for other options. Thanks Larry
POPGUN
PostPosted: Sun Feb 16, 2014 6:18 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Is it recessed and how much do you have to work with? Was it a new plug you were putting in? A photo would help. What is the head made of.
ZANE
PostPosted: Sun Feb 16, 2014 6:32 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
If you use an ease out be sure to use a square tapered one and not a spiral one. The spiral ones will just swell the part you are trying to remove and make it harder to get out.
Zane
ZANE
PostPosted: Sun Feb 16, 2014 6:34 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
You must have the wrong specs????
About 10 ft lbs is all a plug needs.
Zane
LarryNMO
PostPosted: Sun Feb 16, 2014 6:45 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Popgun, Yes the broken threads are recessed and about 75% of the threads is in the head. The plugs were older but not ran that much and I was trying to winterize it when it twisted off. My options for photos are not good. I think the head may be aluminum but not pos., will check with magnet tomorrow. The engine is a 1985. Thanks Larry
LarryNMO
PostPosted: Sun Feb 16, 2014 6:48 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Zane,I do have a tapered squared one and a round one and thats a good suggestion. Thanks
old
PostPosted: Sun Feb 16, 2014 6:50 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Depending on how a GOOD easy out may work. I have good ones but bet your not close enough to be able to use them.
LarryNMO
PostPosted: Sun Feb 16, 2014 7:09 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Thanks Old, I'm not to close to you, I'm in the Wentzville area. I think you are around the lake ozark area. I think I may have one of the good ones, may try it and see what happens.
ARCO petee
PostPosted: Sun Feb 16, 2014 7:13 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Gotta say. I have no idea why they call em easy outs. Break one off and there is no easy way out
old
PostPosted: Sun Feb 16, 2014 7:14 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Ya figured you where not close to me. Yep down here at the lake. The good easy outs are less then 1.5 inches long and cost a good bit. This set I have cost me $75 and that was more then 10 years ago and I have only broken one of them in all that time
old
PostPosted: Sun Feb 16, 2014 7:27 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
By the way what engine is that?? I have a Older Johnson 75 that is a parts engine
LarryNMO
PostPosted: Sun Feb 16, 2014 7:53 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
It is a 1985 150hp mercury
Bob
PostPosted: Sun Feb 16, 2014 9:21 pm    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
Warming the aluminum head up a BIT will help with the extraction process. A LITTLE heat will make the aluminum expand and let go of the remains of the plug... too MUCH heat will encourage the aluminum to continue to stick to the remains of the plug and tear off of the head/attach itself even tighter to the remains of the sparkplug.
Hobo,NC
PostPosted: Mon Feb 17, 2014 5:00 am    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
LarryNMO wrote:
(quoted from post at 06:00:28 02/17/14) Hi guys, I know this is a tractor site, but maybe I can get some help with this problem. I've got a 150hp outboard mercury engine that has the spark plug threads twisted (broken off) in the head. It was being installed to specs (torque) when it broke off. Is there a better way other than an easy out, haven't attempted that yet but just looking for other options. Thanks Larry
Worst case there's nuttin to removing the head.. It would be a good time to replace all those rubber oil lines that run everywhere...
souNdguy
PostPosted: Mon Feb 17, 2014 6:30 am    Post subject: Re: Spark plug threads twisted off in head Reply to specific post Reply with quote
To be fair. most broken ez outs I see are when a person uses one too small. ie. the don't open the hole up sufficiently to use the largest ex out possible, with only a thin shell of the original stuck part in place.
on the flip side.. i also look at the original problem. if it was stuck bad enough that the original whole diameter fastener broke? why gripe if something with a smaller cross section breaks? kinda expected ain't it. Wink ?
Goto page 1, 2  Next
Page 1 of 2
