White 2-180 Battery Hook-Up
newfarmer9
PostPosted: Sat Feb 22, 2014 6:02 pm    Post subject: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
I took the batteries out of my White 2-180 to charge, and now can't remember which way they should be hooked up. I looked in the operator's manual and the service manual, and they show two conflicting diagrams.
The operators manual has the negative posts of the two batteries hooked together and then grounded to the frame, with a cable running from each positive post over to the starting solenoid (parallel).
The service manual shows the negative post of one battery hooked to the positive post of the second battery (series). The second negative post is then grounded to the frame, and the second positive post is connected to the solenoid.
What is the correct way to hook these batteries up?
newfarmer9
PostPosted: Sat Feb 22, 2014 6:21 pm    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
The service manual says "Two twelve volt batteries in parallel", which is what I think is correct, but then the diagram shows two batteries hooked in series?
buzzinduzzin
PostPosted: Sat Feb 22, 2014 6:38 pm    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
look at the starter and or alternator if they say 12 volt then hook 12v batteries in parallel, or two 6v in series
RWT
PostPosted: Sat Feb 22, 2014 6:48 pm    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
If both batteries have a cable hooked to 'chassis' they were parallel.
A cable running from one battery to the other would be series but I
doubt it is like that.
I hope this helps.
RT
G1355
PostPosted: Sun Feb 23, 2014 11:51 am    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
They are parallel, here's a picture of my 2-155 which should be
the same.
newfarmer9
PostPosted: Sun Feb 23, 2014 11:55 am    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
I ended up getting it figured out. They are hooked together in parallel. I just don't know why the service manual would show them hooked together in series???
bv
PostPosted: Mon Feb 24, 2014 10:19 am    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
What is the difference in series and parallel? I just bought a 1555 diesel that has 2 6 volts are the previos owner said it turns over too slow so I want to put 2 12 volts on it so, hook them parellel or in series? Thanks again.
J.Wondergem
PostPosted: Mon Feb 24, 2014 11:01 am    Post subject: Re: White 2-180 Battery Hook-Up Reply to specific post Reply with quote
bv wrote:
(quoted from post at 14:19:01 02/24/14) What is the difference in series and parallel? I just bought a 1555 diesel that has 2 6 volts are the previos owner said it turns over too slow so I want to put 2 12 volts on it so, hook them parellel or in series? Thanks again.
I think I'd have the starter check out first and see How .such drag it has.
