1550 chain coupler
Roger Mesenbrink
PostPosted: Sun Feb 23, 2014 9:02 am    Post subject: 1550 chain coupler Reply to specific post Reply with quote
The splines on the chain coupler shaft on the trans side are worn and loose sko a new sprocket will not help with worn splines, any suggestions?
duane o.
PostPosted: Sun Feb 23, 2014 11:17 am    Post subject: Re: 1550 chain coupler Reply to specific post Reply with quote
Find a" new" to you input shaft thats better than yours or find some shim stock that you can cut to size and tighten up the splines. The coupler must have been loose or a baddly running engine to cause this
Gary Spitznogle
PostPosted: Sun Feb 23, 2014 4:05 pm    Post subject: Re: 1550 chain coupler Reply to specific post Reply with quote
If there is good splines behind the wore out ones Larry sverlack in texas sells a spline you can weld on to new sprocket or a good used one with good teeth.I just done one on 1655. I'll try to find phone # and add
dboll
PostPosted: Sun Feb 23, 2014 5:17 pm    Post subject: Re: 1550 chain coupler Reply to specific post Reply with quote
the best but maybe not the easiest fix is to replace it with a good used or rebuilt input shaft, if the sprockets don't run true it will eat cotter pins and I have seen the chain links swing out and wreck adjacent hyd. lines
SoMiDan
PostPosted: Sun Feb 23, 2014 6:00 pm    Post subject: Re: 1550 chain coupler Reply to specific post Reply with quote
Do like Gary says or you can weld a used gear from the top transmission shaft of any older Oliver tractor. I used half of the main shaft gear or mechanical lift gear from an 88 on my 1550. Then cut the teeth off that gear. Gets it back to good splines.
Gary Spitznogle
PostPosted: Mon Feb 24, 2014 5:21 am    Post subject: Re: 1550 chain coupler Reply to specific post Reply with quote
Larry"s # is 512-633-5014. Also when I do this I use a clutch shaft out of a 77 or 88 with the same splines to be sure it"s straight, then tach in 4 places so it don"t pull crooked
dboll
PostPosted: Mon Feb 24, 2014 5:45 am    Post subject: Re: 1550 chain coupler Reply to specific post Reply with quote
as long as a person is in it that far wouldn't it be just as well to r&r the input shaft? Putting splines behind the sprocket is going to want to pull the sprocket at an angle once the splines wear a little which they will do as a result of the point of pull not being in line with the centerline of the sprocket, sounds like a band- ade fix to me
