On Snap, never did get around the replacing that fan belt...
PeteTheRookie
PostPosted: Sun Feb 23, 2014 6:03 pm    Post subject: On Snap, never did get around the replacing that fan belt... Reply to specific post Reply with quote
stupid is as stupid does.
Moving the massive snow piles with the "66 4500 TLB on Saturday and it starts tat tat tat. "What"s that, that don"t sound good." Shut it down, take a look. Ancient fan belt I should of, could of changed a shredded mess.
Great, Snow is piled 4-5 feet deep in front of bay door to garage that fits the tractor. Been rained on and frozen too. Parked it, covered with tarp. The permafrost ice sheet under the tractor looks so lovely to work on.
Snap, I do not even know the exact belt it is as the 4500 has a alternator conversion gerry rigged on it.
Order 5 ft of v-link belt in the hop ei can run it long enough to move the snow from in front of the bay I need to use.
Pete
Greg1959
PostPosted: Sun Feb 23, 2014 7:12 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
That is pretty much the same question that I have been pondering... I have a Jubilee with FEL and V-link belt that looks pretty worn.
Question is- Do V-link belts hold up the same a regular V belts? It looks like mine seems to stretch over time.
What is anyone else's opinions?
Greg
Fordfarmer
PostPosted: Sun Feb 23, 2014 8:11 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
I've run a few of them, with good results. Especially handy when putting a regular belt in means a lot of disassembly just to get at it. Any belt will stretch some with age and use.
PeteStillaRookie
PostPosted: Mon Feb 24, 2014 4:38 am    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
Will let you know how it works next weekend. Belt should come this week but i will be away on biz till Friday.
More snow while i am away too.
Pete
PeteStillaRookie
PostPosted: Fri Feb 28, 2014 3:39 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
V-link belt arrived. Going to hit 30+ tomorrow, will get it on see if it "works".
Pete
PeteStillaRookie
PostPosted: Sat Mar 01, 2014 3:46 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
It worked!
Ran it for 5 minutes. Shut it down and snugged belt a wee bit tighter. Then ran it hard moving frozen snow mountains.
Looks snazzy too!
Pete
Greg1959
PostPosted: Sat Mar 01, 2014 4:11 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
That is good news! Glad it worked for you. Where did you order it from?
PeteStillaRookie
PostPosted: Sat Mar 01, 2014 5:45 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
Greg,
Amazon. Costs about 3 times what a standard belt costs. But it was worth it.
I used some old telephone wire to sank it around under the crank pulley. Never even had to get on ground.
I tried to post a video link but could not get it to work.
Pete
Greg1959
PostPosted: Sat Mar 01, 2014 6:06 pm    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
Pete- Is that a V-belt or flat 1/2 inch belt? Seems all I can find on Amazon is flat belts...or does it matter? thanks.
Greg
PeteStillaRookie
PostPosted: Sun Mar 02, 2014 4:23 am    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
Fenner Drives PowerTwist Plus V-Belt - 4L 1/2" x 5' - 0428030
Greg, v-link belt. Acts just like a V-belt.
The link is for the 5ft 1/2", I used all of it except v-links, about 4-5"s
Pete
Fenner V link belt on Amazon
Sean in PA
PostPosted: Sun Mar 02, 2014 4:35 am    Post subject: Re: On Snap, never did get around the replacing that fan bel Reply to specific post Reply with quote
The individual links are flat, but when you link them together the tabs that go through to the inside are shaped with a "v" profile so they go down into the "v" of the pulley and work like a v-belt.
