Unstyled D Gasket Question
Justin Krell
PostPosted: Sun Feb 23, 2014 6:56 pm    Post subject: Unstyled D Gasket Question Reply to specific post Reply with quote
Working on a 1926 Unstyled D. I"m reassembling and preparing for paint. My question is what would you suggest to put on the gaskets as a sealer? I have all new gaskets. What should I use for the block to crankcase gasket and also the head gasket if anything?
metal seat man
PostPosted: Sun Feb 23, 2014 7:54 pm    Post subject: Re: Unstyled D Gasket Question Reply to specific post Reply with quote
i wouldn't use anything,soak your head gasket in oil for a few minutes and let it drain and install it,you can use blue goo if you want on the rest,just remember paint won't stick to it
MT RON
PostPosted: Sun Feb 23, 2014 10:04 pm    Post subject: Re: Unstyled D Gasket Question Reply to specific post Reply with quote
Blue goo is about the worst,if any thing use Black,but just a thin coat on the block to main case & nothing on head gasket.Ron
Justin Krell
PostPosted: Sun Feb 23, 2014 10:38 pm    Post subject: Re: Unstyled D Gasket Question Reply to specific post Reply with quote
Thanks for your response!
WeirdDeere
PostPosted: Mon Feb 24, 2014 12:31 am    Post subject: Re: Unstyled D Gasket Question Reply to specific post Reply with quote
I've always liked Permatex High Tack for normal paper gaskets. Makes the gasket stick, a little sealing, but not permanent and you can get things apart later if need be.
Head gaskets, I use nothing.
Brandon
DONMYEIL
PostPosted: Mon Feb 24, 2014 8:27 am    Post subject: Re: Unstyled D Gasket Question Reply to specific post Reply with quote
I use a light film of grease to hold in place and it allows the gasket to move while its tightened down .
rustred
PostPosted: Mon Feb 24, 2014 7:47 pm    Post subject: Re: Unstyled D Gasket Question Reply to specific post Reply with quote
yep on the permatex , that's the only thing I use.
