6V sealed beam bulbs
Goto page 1, 2  Next
tcaito
PostPosted: Mon Feb 24, 2014 4:03 pm    Post subject: 6V sealed beam bulbs Reply to specific post Reply with quote
I am looking for the best place to get a set of 6V sealed beam bulbs for a 420w's head lights. I have seen 6V bulbs listed as "high beam" or "low beam" but they are for 620's and up.. The 420's have a high and low beam setting but I think the power is cut to create the low beams??? Please correct me if I am wrong about that....
flyphoto
PostPosted: Mon Feb 24, 2014 4:53 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
I bought some for my 420 at O'Reilly Auto Parts, they cost around $10 each. I don't know about your high beam question, but I think you are right because it looks like there is a resistor on the switch that could cut current to the lights. Hopefully someone will confirm either way.
58 Deere
PostPosted: Mon Feb 24, 2014 5:19 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
The 620's are 12 volt. And I bought mine at the local NAPA store. I have seen in the books listing both high and low beam lights. Now I do not know which I bought. I do know there is a resistor on the back of the light switch that reduces the voltage to the lights. My lights go from bright and dim. But I do not know if my bright lights are as bright as possible. Any way I can see. Not worth the trouble to change them now.
tcaito
PostPosted: Mon Feb 24, 2014 5:20 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
Thanks! I will give them a try. I went to NAPA and they laughed at me..
tcaito
PostPosted: Mon Feb 24, 2014 5:22 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
I think I am confused at this point. I was on the phone with Stiener this afternoon and they didnt seem to have a clue what sealed beam bulb I needed either..
Ray
PostPosted: Mon Feb 24, 2014 6:08 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
The 420'S I've had used a twist in 6 volt bulb.
The sealed beams were 12 volt,there available at napa or tsc for around 12 bucks.
D-
PostPosted: Mon Feb 24, 2014 7:40 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
Usually where one bulb is used for both high and low they are dual element.
That's usually on later models and 12V.
I thought the tractor you are dealing with used small bulbs behind a lens, not sealed beams.
rustred
PostPosted: Mon Feb 24, 2014 7:45 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
I would laugh also, cause a sealed beam does not use a bulb! it is a sealed beam.
two different animals u are talking about.
bill mart
PostPosted: Mon Feb 24, 2014 9:52 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
the early units used a small bulb, tractors 100001-135742 used sealed beam jd part number AT11121T. 135743 and up used JD AF3893R
bill mart
PostPosted: Mon Feb 24, 2014 9:55 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
Part Details
Part Number: AF3893R
Part Price: 50.16 USD
On Hand: 0 Check Other Stores
Description: Lamp
Package Quantity:
1
All Makes Parts from John Deere Where Used
English Metric
Specification
Weight: 0.55 LBS 0.25 Kg
Design Volts 6.200
Length 2.756 IN
Watts 25.000
Lamp Number 4511
Base Code - Number of Terminals B-2
Filament C-6
Average Life (Hours) 300.000
Candle Power (MSCD) 2,200.000
Finish
Note
bill mart
PostPosted: Mon Feb 24, 2014 9:57 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
af3893r crosses to g.e.4511 available at auto parts stores
tcaito
PostPosted: Mon Feb 24, 2014 10:21 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
Play on words, sealed beam, sealed beam bulb...
I had a oldbulb with me and they told me it was special item they could not get. Thanks for laughing along offering no assistance.
tcaito
PostPosted: Mon Feb 24, 2014 10:25 pm    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
Thank you for the info! I will see what I can come up with tomorrow.
NNP
PostPosted: Tue Feb 25, 2014 4:27 am    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
If the 4511 is what you need, I'd find another NAPA to deal with....common
Also, usually on the shelf at TSC stores
jd_adict
PostPosted: Tue Feb 25, 2014 4:41 am    Post subject: Re: 6V sealed beam bulbs Reply to specific post Reply with quote
I hate to inform you but to my knowledge of the dubuque tractors of this erra that used a sealed beam 6 volt light is NO LONGER AVAILABE.
unfortunitly you will have to buy the earlier style of light unit that has a TURN IN LIGHT BULB.
I have been through this before. there was a certain period that JD tried to use this special sealed beam 6 volt and they discontinued it at the end of the 420 erra. On the new 430 they went to a new design of light like on the rest of the 30 series tractors that had a new design 6 volt sealed beam... the one you can buy today. IT DOES
NOT fit the light unit you have for your 420.
So take the two front lights off put they in a box
marked NFG or parts no longer availabe. Go buy 2 new lights from stiener and put them on. they have to be the bullet style to be original as can be. at a first look you will say the two lights look the same but if you look close the one on your 420w is designed special for a sealed beam. Even the outside ring is different and DOES NOT interchange. the rear light JD always used a turn in bulb so you dont have to worry about a SEALED BEAM not working for it. Hope this helps, I have been there done this. Good luck.
Goto page 1, 2  Next
Page 1 of 2
