Wheel Horse 520H
GLMPA
PostPosted: Mon Feb 24, 2014 6:10 pm    Post subject: Wheel Horse 520H Reply to specific post Reply with quote
When my 520H is running the engine vibration seems to make the hydraulic shifter move and the unit will start to move forward or backwards depending on which way it vibrates. Is there a way to tighten up the hydraulic lever so it stays stationary? Thanks for any input.
joe csuti
PostPosted: Tue Feb 25, 2014 2:35 am    Post subject: Re: Wheel Horse 520H Reply to specific post Reply with quote
There is probably a tension/friction adjust for shifter either on tractor or trans which is probably covered in owners manual,trans manual or both along with instructions for setting netural position of shift.
IF you don't have owners manual/trans manual goto website below,both are avail as a free download in addition to eng manual & hyd lift service manual.
https://lookup3.toro.com/request/request.cfm
El Toro
PostPosted: Tue Feb 25, 2014 5:02 am    Post subject: Re: Wheel Horse 520H Reply to specific post Reply with quote
Check under that shifter lever for a spring that may need to tightened some to keep it from moving. Hal
GLMPA
PostPosted: Tue Feb 25, 2014 7:05 am    Post subject: Re: Wheel Horse 520H Reply to specific post Reply with quote
Thanks gentlemen.
gab
PostPosted: Tue Feb 25, 2014 7:30 am    Post subject: Re: Wheel Horse 520H Reply to specific post Reply with quote
There's a slotted quadrant under the seat with a 3/8" locknut and flat washer, tighten just a hair.
