Loosen bolts?
Charner MS
PostPosted: Wed Mar 05, 2014 2:48 pm    Post subject: Loosen bolts? Reply to specific post Reply with quote
What's the best way to loosen head bolt without popping the head off. Sometimes the pull handle will pop the bolt and sometimes the impact wench will pop it. I've tried Blast-0ff and heat. Which wrench is recommended.
FLAcharlie
PostPosted: Wed Mar 05, 2014 3:47 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
I did mine previous winter. Since I had all the time in the world, I soaked each bolt in Marvel Mystery Oil, plenty of it, for a couple weeks before I started the project. Had no troubles removing them with air impact wrench.
Tom N MS
PostPosted: Wed Mar 05, 2014 4:25 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
How does MMO or any other "penetrating oil" do any good if the bolt is horizontal? I can see how it MIGHT seep down the side of threads if the bolt is vertical.....IMHO most penetrating oil is just a "feel good" thing...
FLAcharlie
PostPosted: Wed Mar 05, 2014 4:48 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
I thought "head bolt" was in reference to the head. I changed the head gasket, and all the head bolts were vertical, not horizontal.
Dean
PostPosted: Wed Mar 05, 2014 5:10 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
Impact.
Dean
Tom N MS
PostPosted: Wed Mar 05, 2014 5:45 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
Hmmmmm-yea I drifted off into senior moment land i guess...My brain was saying/thinking Manifold.....
Colin King
PostPosted: Wed Mar 05, 2014 6:10 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
I think there's a significant improvement on rusted bolts - especially noticeable if you're trying to wrench by hand rather than impact. I've had nuts and bolts I couldn't turn, but after a few days of soaking with PB, came apart with relative ease.
Colin
maxwell99
PostPosted: Wed Mar 05, 2014 7:00 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
check this one out:
they say ATF and acetone
50/50 solution is the best penetrating oil
who knows, if you got the nuts off and did not break any bolts, you have the best penetrating oil.
to me, heat is the best, but some times you can not use heat.
http://www.cyclefish.com/forum/The-Garage/General/Penetrating-Oils---Which-works-best-on-Rusted-Nuts-amp-Bolts-132611-1.html
I would reinstall with new nuts as the old ones after torqueing may have stretched threads.
Den N Ms
PostPosted: Wed Mar 05, 2014 7:10 pm    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
Tom,by a process known as wicking,Kroil and PB are both good at wicking.
s19438
PostPosted: Thu Mar 06, 2014 1:47 am    Post subject: Re: Loosen bolts? Reply to specific post Reply with quote
same here.
